MEVI - EGR Gasket question
Old Jun 3, 2003 | 06:44 PM
Shoooter_j's Avatar
Got the MEVI in, but how critical is it to have the EGR gasket on?
I forgot to put it back on during the install of the VI, and it seems like it would be quite a lot of work to put it on
Old Jun 3, 2003 | 07:38 PM
XXXL Cracker's Avatar
You will need it
You will have a vacuum leak without it. You do not have to remove the whole manifold to replace it. I did the same thing and just loosened a few bolts and slid it in.
D
Old Jun 3, 2003 | 08:10 PM
Shoooter_j's Avatar
Re: You will need it
D
Thx man
Old Jun 3, 2003 | 08:26 PM
Ramius83
Actually, to be honest with you, I also forgot to install the gasket. I started the car and it turned over, but immediately turned off. There was a HUGE leak that you could hear. So, I looked on the USIM and saw the gasket permanently attached to it. I was a little p!ssed off to say the least......
Old Jun 3, 2003 | 08:31 PM
Shoooter_j's Avatar
Mine doesn't seem to have a leak, and it runs fine, but I guess I'll still install it for peace of mind.
Old Jun 4, 2003 | 03:48 PM
costcowholesale's Avatar
his car just died he said the starter wouldn't turn we tried to slip the EGR gasket in but theres no room there so we didn't touch it. but we hooked everything backup and he drove off w/o problem. He went to the store 20mins later to get soemthign and its dead right now.
Old Jun 4, 2003 | 05:48 PM
dwapenyi's Avatar
Man, I do not envy you looking at your USIM and still seeing the gasket attached If that happened to me, as I'm sure I'm capable of, I would've thrown some tools out the window
DW
Old Jun 5, 2003 | 12:03 AM
Requin6's Avatar
are you leaking coolant? i know coolant passes through there with the 2 hoses on both sides of the EGR. i would get that gasket in there ASAP with some RTV red to ensure a proper seal.
--Paul
Old Jun 5, 2003 | 08:00 AM
Shoooter_j's Avatar
Funny thing...I pressed down on the gas and cranked it @ the same time, and she fired right up. It doesn't look like I'm leaking coolant, as we didn't see any signs of "wetness" in the area. The car is working fine for now tho :\ Hope that was just a freak case.
shilov
Feb 19, 2024 09:40 PM
BkGreen97
Apr 2, 2016 05:47 AM
JoshG
51
Sep 21, 2015 10:41 PM
bumpypickle
Sep 20, 2015 08:22 AM
videomano
Sep 8, 2015 03:28 PM
