where can i get loger studs for my wheels???
i currently have 18 konig verdicts on my 2001 maxima....
but i need spacers in order to install the 300zx brakes
the studs that are currently on the car are not long enough for me to install spacers, cuz there are only a few threads of the stud that are in the nut....
Originally posted by Ramius83
Just go to your local parts store and get the 300ZX studs, they are much longer....
I have a 2k and I believe the 96 wheel studs are the same. I got longer ones from Dave B. They are off a Nissan Quest. They are about 5 or 6 millimeters longer than my stock studs. So check with him. The only thing is they are $5 a piece!!! Maybe at a local auto parts store you can get them a little cheaper.
Originally posted by Nealoc187
You know this for a fact? I was at the parts store for like 30 minutes today we were trying to find a longer stud that would work. Nismo studs are available but they are $8 a piece. This will make things alot easier if the 300ZX studs are indeed much longer.
You have to make sure the knurl diameter is the same. That is the part of the stud that fits and grips in the hole of the hub. If it's too small then it won't be tight enough and slip, if it's too big then it won't be able to fit on.
Possible stud alternative.......
http://www.zhome.com/ZCMnL/tech/wheelstd.html
New lug nuts required.
Andy29
09-29-2015 05:32 AM
