Metal Master pads and rust?
Old Jun 23, 2003 | 06:48 AM
thw625's Avatar
I switched to Metal Master pads in the fall and they were good through the winter. Now since the spring they've began to squeal a bit and if they're ever wet when I park and the car sits for a day or two the pads rust and bind to the rotors (rears with emergency brake on). It takes a pretty good rev of the engine to break them loose sometimes, makes me flinch whenever it happens, sounds painful, wondering if it's doing any damage? Has anyone else had this problem? Is there anything I can do to prevent this from happening? Thanks
Old Jun 23, 2003 | 06:51 AM
njmaxseltd's Avatar
I'm running those pads and don't experiance anything like that
Old Jun 23, 2003 | 10:13 AM
97GLES's Avatar
i don't think it's my pads but every time i wash my car or it rains my rotors rust up. i have 19" wheels with small spokes so i get to see it all the time. it all goes away when i drive for about 1 block.
Old Jun 23, 2003 | 10:31 AM
ZuMBLe's Avatar
Rust on the discs are normal. The discs are made of iron not stainless steel.
ZuM
Old Jun 23, 2003 | 03:48 PM
jack63ss's Avatar
Okay, so my first thought was to answer, "So don't take your max out in the rain". But really, I have standard pads and I have the same problem if the car sits for 4-5 days without moving. Why it happens to you so quickly might be based on what condition your rotors are in. Did you have them turned when you put on the MetalMaster pads ? You will probably have to replace the rotors next time anyway, but you should probably have them turned whenever you change pads (at least that is what my mechanic, who does not do my brakes, said).
Old Jun 23, 2003 | 03:59 PM
sleeper's Avatar
sticking
i haven't had any problems as far as damage occuring when the pads stick from rain causing rust.
Old Jun 24, 2003 | 07:05 AM
xHypex's Avatar
Re: Metal Master pads and rust?
I heard a pop the other day, but never even though about it being the brakes. Generally I park my car in the garage, but I had to park it outside for a few days during which it rained a good deal. It was probably outside for 3-4 days, and the pop was pretty loud (sounded like it was mostly DF). I have Axxis Metal Masters as well.
You car is garaged isn't it?
-hype
Old Jun 24, 2003 | 07:10 AM
njmaxseltd's Avatar
Re: Re: Metal Master pads and rust?
-hype
Nope, the Garage is reserved for the Bike and a few other toys.
Old Jun 24, 2003 | 11:45 AM
Dave Holmes's Avatar
Rotors will rust. You can paint the non-contact portions to keep them looking good. The portions of mine where the pad contacts will rust within an hour after using rim cleaners. No big deal, it's gone on my first braking.
Sounds like your rear pads aren't sticking to your rotor, but your parking brake is not fully disengaging. This can be from the cable rusting a little in the sheath, or just being dirty. When you give it gas, it overcomes the rust/dirt resistance, and will release with a "pop" sound. It is free to check the parking brake cable, and it is a common problem. Definitely worth checking.
Dave
Old Jun 25, 2003 | 06:36 AM
jack63ss's Avatar
"Sounds like your rear pads aren't sticking to your rotor, but your parking brake is not fully disengaging. "
Very good point, as I have had this problem with two previous cars. Assuming you use the parking brake (since some people do not), try not using it and see if the problem goes away. Oh, and if you do not use it, it is actually MORE important that you keep the cable clean as it WILL stick when you really need it (Murphy's Law of Cars #72).
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
RealityCheck
Oct 2, 2015 06:34 PM
uttadms31
Sep 30, 2015 05:24 AM
