SARD FPR may have takena dump...
Old Jun 23, 2003 | 11:08 AM
jdmmax's Avatar
ok so i got my idleing problem fixed.
now i have another problem.
my fpr will stay at my WOT setting.
i am trying to figure out if i have another vacumm leak some where or if the fpr took a dump.
has anyone ever experienced this problem with the SARD fpr.
i checked all vacuum lines and again can't find a leak.
any thoughts
it is problem after another the last 2.5 weeks. and it is beginning to waredown my patience level.
Frank
Old Jun 23, 2003 | 11:18 AM
Jeff92se's Avatar
I'm needing a caw
Aren't those adjustable? Tried fiddling with the adjustment? If you have vacuum to the sard, then it's probably not a vacuum problem(unless the signal is really low and can pull back the FP at less than wot).
Old Jun 23, 2003 | 11:26 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
Mine crapped out on me last week, I'm going with the aim fpr now...
The sad part is i bought it 6 months ago, and sard is no longer available in the U.S., it's gotta be imported from japan - this means that no warrenty is implied.
Old Jun 23, 2003 | 11:30 AM
turbomax97's Avatar
My sard fpr crapped out on me last week too, i'm gettin an aem fpr... Also sard isn't available in the US anymore, so there's no luck trying to get it warrentied out - i've only had mine for 6 months
Old Jun 23, 2003 | 11:48 AM
jdmmax's Avatar
well i ran a vacuum check and and i got 5 in hg
then i waited a while and it went up to 10 in hg and stoped right there.
what sould normal vacuum be like i unplug the vacum line and there is no vacuum. everyother vacummline i pull my figure gets sucked on to the end. why is it just one vacuum line???
Old Jun 23, 2003 | 12:14 PM
sx7r's Avatar
trace that vacuum line to the source and see if there's anything wrong with the line. vacuum at idle is usually about 17-19in Hg.
Old Jun 23, 2003 | 12:17 PM
jdmmax's Avatar
hmmm will do thanks.
Old Jun 23, 2003 | 01:58 PM
Ramius83
Like SX7R said, it sounds like you have a vacuum leak, which is simulating WOT conditions for the SARD. Re-check all lines again. Good luck JDM.....
Old Jun 23, 2003 | 10:35 PM
jdmmax's Avatar
ok it was a pinched off vacuum line.
Old Jun 23, 2003 | 10:40 PM
sx7r's Avatar
good deal.
Old Jun 24, 2003 | 12:52 AM
jdmmax's Avatar
yeah i was really begining to worry thanks for the help.
i really didn't want to buy anything else that was not a power adder.
msellas
Sep 23, 2015 09:16 PM
SLC I30t
Feb 4, 2003 02:55 PM
Ramius83
Dec 12, 2002 11:26 PM
Stikya
Nov 12, 2002 03:03 PM
ejj
Jun 20, 2002 02:46 PM
