Couple new pics from my cardomain page: 13" brakes and missing MEVI valve
Old Jun 25, 2003 | 12:32 PM
Nealoc187's Avatar
SLOW
For reasons I don't care to go into right now (read-"my own stupidity") I am unfortunately running stock calipers on my 13" rotors right now. But they work. They work too well, hence my need for R compounds. I'll post the details of my setup and what happened later.
I decided to check my MEVI valves because people had been having problems with them. I popped off the cover and look what I found.
You can see one screw to the left of the detatched valve. The other screw was in the little opening below and between the two Ws in the text I wrote on there. I don't know what happened to the little arrow I had put on there. I got lucky.
Old Jun 25, 2003 | 12:35 PM
MaximaMoJo's Avatar
I would go buy a lottery ticket if I was you.
Old Jun 25, 2003 | 01:38 PM
ejj's Avatar
ejj
Neal, did you use loctite or anything? I assume that was my mistake...but if you did...
This seems to be getting more and more common.
Old Jun 25, 2003 | 01:43 PM
ejj's Avatar
ejj
Re: Couple new pics from my cardomain page: 13" brakes and missing MEVI valve
What was involved to make the stock calipers work the the 13" rotors? Could this be a semi-break upgrade for people that can't use Z calipers because of their wheel offsets (read: ME!)?
Are they much better than stock?
Old Jun 25, 2003 | 02:00 PM
Nealoc187's Avatar
SLOW
Re: Re: Couple new pics from my cardomain page: 13" brakes and missing MEVI
Yes they are MUCH better than stock. Good enough that even my brand new Toyo T1-S aren't cutting it at the track anymore (I'm talking about road course here, not drag strip). I can't apply more than 50% pedal effort or I'm locking them up. I'll email you with details later tonight but I have to head to work now.
No i didnt use loctite I just tightened them down real good with a large screw driver rather than the puny one I used before. I will be putting some superglue or something on them later, but my MEVI is out of commission right now anyways, I fried my harlan switch somehow.
Old Jun 25, 2003 | 02:38 PM
Jeff92se's Avatar
I'm needing a caw
Very nice work Nealoc. But you have made lemonaid out of lemons in this case. The Cobra rotor + stock calipers should be a very nice compromise brake upgrade kit. Especially if they work even nearly as well as you experienced.
Old Jun 25, 2003 | 03:21 PM
deezo's Avatar
Re: Re: Re: Couple new pics from my cardomain page: 13" brakes and missing MEVI
Things like this make me glad I didn't rushto put this thing on. Over the weekend I used Loctite's Superglue on all of the screws but maybe it was a good idea to glue the valves to the rod too.
Old Jun 26, 2003 | 06:47 AM
Ramius83
Neal: Aren't those your 15 inch Kosei's?????? If you are using the stock calipers there, won't the 300zx calipers touch the inside portion of the rim? Anyways, I would like to talk to you about the bracket you used.....
Old Jun 26, 2003 | 07:58 AM
BJJ's Avatar
BJJ
I am just wondering if those brakes will clear the rims you run slicks on at the track, because it looks like a fairly tight fit on the 17's from the pics.
Old Jun 26, 2003 | 10:52 AM
ZuMBLe's Avatar
oh boy.. I'm going home later and putting some loctite red on them! I'm scared now.
Old Jun 26, 2003 | 06:47 PM
Nealoc187's Avatar
SLOW
I don't have 15" Koseis. I have 17" Koseis. 13" rotors and calipers wouldnt have a prayer of fitting under 15" wheels.
If I go drag racing I will either do it on my street tires or I will swap out the rotors and put 300zx rotors on.
Old Jun 26, 2003 | 07:34 PM
I30tMikeD's Avatar
Thanks for the heads up on the screws Neal. Thank god everything was OK.
Old Jun 26, 2003 | 08:53 PM
teejnut's Avatar
Do you think the 16" Koseis will fit with teh 300ZX calipers and rotors?
Old Jun 27, 2003 | 03:56 PM
KMax2988's Avatar
Should. My buddy had 15" K1's with Z32 brakes all around (front and rear) on his Silvia.
halfpol
Oct 17, 2022 12:16 PM
homeyclaus
Sep 3, 2015 06:15 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
halfpol
Aug 5, 2015 08:24 PM
