Cams 12-15 horsepower?
Old Jul 1, 2003 | 02:09 PM
krismax's Avatar
Father of the 00 VI
I just goy of the phone with ben at JWT and he said 12-15 hp for the cams which i thought everyone was saying it was higher,and he said with VI ,cams and ECU he still wouldnt go over 7000rpm with the springs ? anybody have any ideas.
Old Jul 1, 2003 | 02:39 PM
drewm's Avatar
The HP figures for the cams sound about right, but for $1000 for the cams and another $1000 for the install, it sure doesn't sound like very much bang for the buck. You'd get a lot more out of supercharging.
The problem with the 7000 rpm limit is the valve springs. They either need to be replaced by stronger springs or shimmed to prevent valve float.
Old Jul 1, 2003 | 02:47 PM
krismax's Avatar
Father of the 00 VI
See it doesnt sound right to me i seen dynos of sr20de and honda engines gaining 25-30, Im seriously thinking about buying them , i figured are stock cams are very mild and you would think they would take advantage and make some cams with some nice power i dont care about a rough idle.
I would get them installed for $300.
Old Jul 1, 2003 | 03:10 PM
delio's Avatar
1st rule of dealing with JWT...
Don't pay much attention to what Ben says
Old Jul 1, 2003 | 03:42 PM
releasedtruth's Avatar
rilla dope
I agree with the boosting instead, but you can get better valve springs as well so I would use the cams at the very end of an all NA setup or to grab more power after you blow 5k on other boost/performance adders.
Old Jul 1, 2003 | 03:52 PM
nismology's Avatar
Would it be possible then to just buy the intake cams instead of all 4? Seeing how expensive they are and all.
Old Jul 1, 2003 | 05:02 PM
MaxSpeedSE's Avatar
I heard today that cams wont do Sh*T unless u have the exstended Rev limiter...is this tru?
-Chris
Old Jul 1, 2003 | 05:16 PM
Jeff92se's Avatar
I'm needing a caw
Nope
-Chris
Old Jul 1, 2003 | 05:31 PM
96sleeper's Avatar
Originally posted by Jeff92se
Nope
That is not entirely true, the full potential of cams won't be realized without an extended redline. Yes, there can be gains, but they will be minimal compared to cams with 7000rpm or higher redline. I see LS1 guys with $2k heads/cams packages that don't gain more than one tenth in the 1/4 mile until they move the rev-limiter, then they see a half-second gain or more.
Old Jul 1, 2003 | 07:54 PM
I30tMikeD's Avatar
Death, taxes, and JWT taking forever on my ECU are the only sure things in life.
Old Jul 2, 2003 | 07:09 AM
xHypex's Avatar
I know there are no dyno numbers for JWT cams, but I would say its more than 10hp. After driving a car with JWT cams and a VI you don't even feel/hear the VI engage. That means the VI isn't making nearly the same power as the cams as a relative percentage.
The next consideration would be driveability. The JWT cams make the car lope and sound more like a domestic, and there is absolutely no power before 3500. Normal stoplight driving with an ACT usually bogs the engine a little, but once you hit cams its really nice JWT also has stronger valve springs so you can rev higher.
-hype
Old Jul 2, 2003 | 11:40 AM
krismax's Avatar
Father of the 00 VI
-hype
When you talk about the stronger valve springs i wonder why the guy at JWT told me no matter what the power adders i add for my car there is no sense going past 7000rpm.
If you can feel the horsepower like that it has to be better than 10hp.Also if i got these what rpm should i go to 7500rpm?
infinitiblast's Avatar
What are the duration specs on these?
Old Jul 2, 2003 | 12:55 PM
ZuMBLe's Avatar
Still don't have your ECU huh? how long has it been? At least when you get it.. you can just swap ECUs.
Old Jul 2, 2003 | 01:05 PM
Jeff92se's Avatar
I'm needing a caw
He said "won't do ****", which I took as nothing. Which was wrong. But as a whole I agree with you 100%
Old Jul 2, 2003 | 11:04 PM
nismology's Avatar
Umm... Is this such a rediculous question that it doesn't merit a repsonse?
Old Jul 2, 2003 | 11:47 PM
xHypex's Avatar
Yes
-hype
Old Jul 3, 2003 | 12:30 AM
I30tMikeD's Avatar
Going on 7 weeks. It does not really matter now since my tranny is toast and my VI is not working
Old Jul 3, 2003 | 12:58 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
well....labor rate i belive calls for 10.2 hours to remove and replace cams. if your spending so much time to replace them, its kinda stupid to replace only the intake cams. either replace all 4 or juss save the money for something else.
Old Jul 3, 2003 | 05:59 AM
MaxedOutR34's Avatar
Re: Cams 12-15 horsepower?
How did you do the pathfinder TB? I've havent been able to find any instructions on it. Also check out www.Paeco.com. They do a lot with the older 3rd gen maxes and 300zx's, especially cam work.:attention
Old Jul 3, 2003 | 06:22 AM
ereet's Avatar
Cam's are only 10-12 hours to put in for the four? *evil idea*
How much are these things again? (for the set -- not for each cam)
Old Jul 3, 2003 | 06:32 AM
krismax's Avatar
Father of the 00 VI
Re: Re: Cams 12-15 horsepower?
I actually sell the plate its in group deals,there are pictures there too.
The cams are $1100.
Old Jul 3, 2003 | 10:50 AM
delio's Avatar
Didn't I warn you on the OT thread a while back?
Old Jul 3, 2003 | 11:55 PM
Nealoc187's Avatar
SLOW
I'm not entirely convinced they would only give 10-15 hp either. I was thinking more along the lines of 15-25hp.
Anyhow their response that "going above 7000rpms is useless" is utter rubbish. Valvetrain is THE limiting factor to this. If you have cams with the correct specs and a valvetrain that can handle it, there is absolutely no reason this motor couldn't rev to 8000rpm. The stroke on the VQ is so short that piston speeds will remain low, even with it cranking at 8000rpm.
The MEVI alone lets power hang on til at least 7200, and I'd venture to say (though no one's been there in an N/A MEVI stock cammed car) that the MEVI alone could sustain power levels to about 7500rpm. With a set of cams that have specs such that they shift the powerband northward about 500rpm, an 8000rpm cammed and MEVI'd VQ would be a gem.
I've got a few emails to send to various companies with regards to this. If I find anything interesting I will let you guys know.
Old Jul 4, 2003 | 07:24 AM
MaxSpeedSE's Avatar
Niiiiice Keep us updated
Old Jul 4, 2003 | 07:29 AM
krismax's Avatar
Father of the 00 VI
Mardigrasmax said in one thread ,that the supra springs and Ti retainers could be used from crower ,whole kit $376, do you think a supra has 24 springs and retainers? I dont know if he said the 2jzgte or not? Ill buy these on monday if thats the case. thanks
Old Jul 4, 2003 | 08:14 AM
Nealoc187's Avatar
SLOW
I'm not sure that he was talking about the 2JZ or 7M but I'm sure either of them is a 24 valve motor.
You could also use VQ35 retainers they are cheap as hell. See if you can just get the springs and then get the retainers from nissan and you can save yourself some $.
The JWT set is supposed to be $400 though, so $376 isn't a ton cheaper. Check with Mardigras on the Supra stuff and JWT on the Max stuff. Also before you go buying anything check with SGP Racing they have Tomei cams available in 256x10.2mm, 264x10.2mm, and 268x10.5mm.
It also says on SGPs website that the stock 2024 Al retainers are very weak. Not sure if this is true or if they are just trying to peddle their product, but it's something to think about. I wouldn't go rushing into a cam purchase just yet I think this is just the tip of the icerberg for the VQ because of the budding 350Z/G35 market.
Old Jul 4, 2003 | 08:37 AM
krismax's Avatar
Father of the 00 VI
Thanks, mardgras was also saying that you shouldnt go past 7200rpm with aftermarket cams with the alum retainers.Does JWT for $400 have the TI R.
Iwent to SGP racing site ,i noticed their all for the vq35de, are they completly interchangble with vq30de?Have you ever saw claimed power gains?
Well i never knew there were other choices ,maybe ill take it easy.
Old Jul 4, 2003 | 08:47 AM
Nealoc187's Avatar
SLOW
The impression I got is that they are interchangable but I couldn't say for sure. Maybe call JWT about that since they have cams for both cars. They may just be different specs or something?
Anyhow I emailed SGP a little while ago and the guy there said to email him back in like 4-6 weeks because he was trying to get dyno graphs from Tomei. I'll email him again but I wouldn't expect a reply til Monday since it's a holiday.
spazma7ik
Jan 12, 2017 09:38 PM
gustavison
Oct 4, 2015 06:50 PM
Max139617
Sep 29, 2015 06:44 PM
conansriver
Sep 11, 2015 10:26 AM
