Shifting When A/C is on (Stick Shift)
Old Jul 7, 2003 | 03:49 PM
nismotech's Avatar
When I'm driving w/ air condition off I can shift smoothly anywhere from 2000RPM~whatever, but it seems like I can only manage to shift smoothly with my A/C on when I'm shifting around 3000RPM(or higher) or else the RPM drops pretty fast as soon as i disengauge the clutch to up shift and my car will jerk (If I shift at or less than 2700 RPM)
Is this normal? I dunno, maybe you experienced expert can fill me in on this. I've been driving my first stick shift for about 10months.
P.S. Moderators please delet the "Shifting Gears when A/C is on Kinda different " thread, it got screwed up for some reason so it doesn't show correctly.
Old Jul 8, 2003 | 09:54 AM
image's Avatar
hmm Ive heard that once your AC is off it stops using that pully therefore giving u extra HP. I always race with my AC OFF. Wierd tho...
Old Jul 8, 2003 | 10:54 AM
PiotrC70's Avatar
When I origanally dyno'd my car in the fall, I usually keep my keep my front defrost on low. I dynoed about 7 hp more w/ it off and about 10 tq more w/ it off... I can't imagine how much the A/C will rob you. Definately keep all accessories off when either racing or dragging.
Old Jul 8, 2003 | 01:38 PM
nismotech's Avatar
So neither of you guys feel a differen't feeling in gear shift and clutch release between when A/C is on or off? and I'm just talking about normal driving, not racing.
If you guys shift with a/c on at 2500RPM the car won't jerk or anything?
Old Jul 8, 2003 | 03:51 PM
JeffesonM's Avatar
living out of a maxima...
It may feel a little different becuase even with the clutch in, the engine is still under load.
Old Jul 8, 2003 | 04:46 PM
Neptune97's Avatar
Its completely normal to feel both a slight stutter in acceleration, as well as a jerkier clutch engagement, when you turn the AC on. The jerkiness of the clutch engagement will be exaggerated even further if you have an aftermarket clutch, which wants to engage even harsher with the increased engine load.
Old Jul 8, 2003 | 05:27 PM
nismotech's Avatar
Thanks for the help, all I need to know is its "normal" to feel a bit different in clutching and shifting actions when the a/c is on.
so for those of you driving with a/c on, what RPM do you guys usually shift at? during regular driving?
Personally, I shift around 3000RPM for a smooth shift.
Old Jul 8, 2003 | 05:30 PM
JeffesonM's Avatar
MEVI = 6800
Old Jul 8, 2003 | 05:54 PM
nismotech's Avatar
Originally posted by JeffesonM
MEVI = 6800
Your MPG must be horrible~~
Old Jul 9, 2003 | 09:25 AM
JeffesonM's Avatar
Old Jul 9, 2003 | 12:52 PM
dwapenyi's Avatar
Yup. It's normal. Here's a bullet proof way to shift the 5 speed:
AC OFF
1-2, shift relatively slowly, the gears are spaced wide apart.
2-3, 3-4, and 4-5, shift fast as the gear ratios are closer and synch better with fast shifting.
AC ON
Same as above excpet 1-2 you now have to shift fast because the rpms are dropping faster, fast enough to even accomadate the wide gear spacing.
DW
Old Jul 9, 2003 | 01:04 PM
CoolMax's Avatar
is invisible
Turn off A/C while shifting.
Old Jul 9, 2003 | 02:36 PM
image's Avatar
haha. good one!!!
Old Jul 9, 2003 | 02:49 PM
nismotech's Avatar
I usually drive with my windows down, even during a 80+ degree day, but its been reaching 95F lately I can't stand driving without A/C no more
Old Jul 9, 2003 | 02:50 PM
image's Avatar
I live in HOUSTON TX! We invented AC. WE HAVE TO HAVE AC! So when I race I turn it off and suck it up.... :P
Old Jul 9, 2003 | 02:51 PM
nismotech's Avatar
AC OFF
AC ON
DW
What RPM do you shift at using these steps?
Old Jul 9, 2003 | 03:00 PM
dwapenyi's Avatar
This is for normal day to day driving, when you're in the 2000 - 3500 rpms range. If you're 1/4 miling, then just shift as fast as you can
DW
Old Jul 9, 2003 | 03:48 PM
nismotech's Avatar
DW
Thx!
Old Jul 10, 2003 | 09:37 AM
CoolMax's Avatar
is invisible
Really, it shouldn't be too much trouble to reach up before the shift and turn off the A/C, then turn it back on after the shift, right? Problem solved!
Old Jul 10, 2003 | 12:10 PM
nismotech's Avatar
Turning the Air Compressure ON and OFF constantly can't be good... Is that how you drive your car?
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
