CV Joint?
Old Jul 8, 2003 | 08:46 AM
jqhao's Avatar
CV Joint?
When I start engine today, there is some sharp noise (Zhi Zhi) in the front of the car, it looks like from the front wheel.
Is it a problem of CV joint?
Thanks.
Old Jul 8, 2003 | 09:12 AM
snowman2155's Avatar
If it clicks when u turn, then it's cv related.
Old Jul 8, 2003 | 09:15 AM
jqhao's Avatar
Thanks!
I did not make a turn, Just start the engine and no move.
is it still be CV joint?
Old Jul 8, 2003 | 09:24 AM
ejj's Avatar
ejj
Originally posted by jqhao
Thanks!
No. The CV joint won't make noise unless the car is moving.
Old Jul 8, 2003 | 09:56 AM
jqhao's Avatar
Thanks!
What kind of problem can it be? transmission or engine?
Old Jul 8, 2003 | 09:59 AM
ejj's Avatar
ejj
Thanks!
What transmission do you have?
Is it right after the car starts only? Maybe the starter?
Old Jul 8, 2003 | 10:28 AM
smrtazz_97's Avatar
Re: CV Joint?
Thanks.
Belts???
Old Jul 8, 2003 | 10:46 AM
jqhao's Avatar
Re: Re: CV Joint?
Originally posted by smrtazz_97
Belts???
The car is 93 Maxima Auto.
You mean time belt?
Old Jul 8, 2003 | 01:11 PM
jqhao's Avatar
Re: Re: Re: CV Joint?
You mean time belt?
Actually, the noise (zhizhi) lasts for a few seconds, it stops and appears after a while. (The car does not move)
If it is from the lossing belt(s), should I go to mechanics asap? how much will cost?
Thanks.
Old Jul 8, 2003 | 01:13 PM
ejj's Avatar
ejj
Re: Re: Re: Re: CV Joint?
Thanks.
Which "front wheel" is the noise coming from?
Old Jul 8, 2003 | 01:25 PM
jqhao's Avatar
Re: Re: Re: Re: Re: CV Joint?
Right front wheel.
Old Jul 8, 2003 | 01:29 PM
ejj's Avatar
ejj
Re: Re: Re: Re: Re: Re: CV Joint?
Right front wheel.
I agree then, it sounds like its the belts squealing.
Typically its not a big deal, just annoying. It usually means that they either aren't tensioned properly or are starting to become too worn.
If you can do it yourself it would cost less than $30. At a mechanic you shouldn't have to pay more than $100 for new belts installed.
Old Jul 8, 2003 | 01:37 PM
jqhao's Avatar
Re: Re: Re: Re: Re: Re: Re: CV Joint?
Thanks!
What kind of belts should they be? The noise is really annoying although it looks like not to affect my driving now.
Old Jul 8, 2003 | 01:39 PM
ejj's Avatar
ejj
Re: Re: Re: Re: Re: Re: Re: Re: CV Joint?
Thanks!
Not sure what you mean. There are 2 belts, the Power Steering belt, and the Alternator/AC Compressor belt. If you're going to replace one you should replace both.
You could use generic belts from a parts store, or Nissan belts, shouldn't make a difference. As long as they are tensioned properly, any (assuming the correct size) will work.
Old Jul 8, 2003 | 01:46 PM
jqhao's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: CV Joint?
What if I do not replace them now since I am really busy now? will there some bad results?
James92SE
142
Jan 2, 2024 09:23 AM
user 11122324
42
Jul 18, 2022 03:35 PM
AaronL
Nov 15, 2020 11:52 AM
ivorton23
Sep 26, 2015 09:47 AM
Bonka
Sep 14, 2015 11:18 PM
