Help car wont rev past 2k rpm??
Old 07-14-2003, 02:34 AM
maseo77's Avatar
just finished installing a water temp gauge today, after installing air fuel ratio and volt gauges 2 months prior no problems...let the car warm up for a few mins and then it cut off on its own...took a few seconds for the engine to turn over but it did but now car bogs down when i try to go past 2k rpms....any ideas???
2k 5sp..short ram intake
maseo77 is offline
Old 07-14-2003, 03:35 AM
VG Ridah's Biatch Hoe
Bags's Avatar
Blown MAF?
Sounds like a blown MAF to me.
Check the 5th gen fourm
Bags is offline
Old 07-14-2003, 05:06 AM
Blu
the tits
Blu's Avatar
will it go past 2200 rpms at all. If it feels like your hitting a rev limiter at 2000-2200 its a blown MAF.
Blu is offline
Old 07-14-2003, 09:29 AM
maseo77's Avatar
i disconnected the water temp gauge from the temp sensor under the hood now problem gone..?? i dont know if i hooked it up correctly?
maseo77 is offline
Old 07-14-2003, 03:21 PM
GreenMaxVE's Avatar
Sounds like you shorted out the power to the MAF, check your wiring.
GreenMaxVE is offline
Old 07-14-2003, 08:11 PM
maseo77's Avatar
i spliced the water temp sender wire rather than the water temp sensor wire, problem solved.
maseo77 is offline
Lakersallday24
06-16-2019 01:35 AM
kjlouis
11-24-2018 06:09 AM
JMag90
08-25-2015 09:17 AM
MaximaDrvr
08-19-2015 08:20 PM
doobadoo
08-15-2015 06:43 PM
Quick Reply: Help car wont rev past 2k rpm??
