Pictures of my Oil cooler/Mocal/Aeroquip fittings, etc.
Old Jul 16, 2003 | 12:53 AM
[maxi-overdose]'s Avatar
probably not a hot topic here since everyboy just gets a Stillen or Permacool one....but just for ppl who's interested in putting togther an oil cooler themsevles, this might help. Do people here use oil cooler? I guess not too many except the boosted crowd.
clicky.....
http://www.cardomain.com/member_page...=239608&page=8
it took me a month to gather all the parts, 2 test fits, and about 6 hours to isntall it. I started with a straight hose fitting from the mocal and turned out there wasnt enough space.
some random notes....
-it is easier to install the mocal with a deep hex socket. I forgot the size, but it is not in metric for sure.
-need at least two adjustable wrench. You will scrach the pretty aeroquip fittings for sure. or you can get the aeroquip wrench. but that's 200 dollars a set!
-use teflon tape on all threads! skip 2 - 3 threads from the top and wrap it clockwise.
-dont forget to apply some oil to the rubber gasket on the mocal.
-This oil cooler only holds 200ml of oil. plus the capacity of the hose...it probably holds 300ml max.
-You will need a total of 9 ft (exit and return) of hose to route the cooler to the driver side.
-can't tell any change on performance. but my blower is cooler now.
Old Jul 16, 2003 | 04:45 AM
Confused's Avatar
Permanent Maxima.org Resident
nice job... it gets expensive but i think you have a better product than the stillen kit.
one comment though:
the hose is not seated correctly on the aeroquip fittings.. it should be flush against the stop.. also be careful about overtightening those kind of hose clamps on the socketless hose.
Old Jul 16, 2003 | 05:13 AM
Donkey®'s Avatar
wat
I think the Stillen kit is just fine. People like to trash Stillen just to trash em.
Old Jul 16, 2003 | 05:21 AM
PCGuRu2K's Avatar
I've been waiting for my Stillen Oil cooler for the past 2+ months now.. There on backorder.. But they did say they'll ship it out this week. But then again that's waht they told me 1 month ago..
Old Jul 16, 2003 | 07:37 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
The Mocal is calling for SS lines!
Old Jul 16, 2003 | 07:57 AM
SS line will poke my pretty fingers
thx for recommending the mocal!
Old Jul 16, 2003 | 08:01 AM
one comment though:
thx~
sharp eyes~ yup....I've tried everything to push that sucker all the way in. It is impossible....I put the fitting in the freezer, heat up the hose, lubricate the fitting, etc. but it just wont go all the way in! Ideally, it doesnt even need a hose clamp but I finally gave up on it.
I assume that I shouldnt overtightening the hoseclamp because it will crush the fittings?
Danny : can you take some pictures of the stillen kit once you received it? I want to see how stillen route their oil line. thx in advance.
Donkey man: I agree with you. Stillen does carry some fine products. I didnt buy a stillen kit is because it doesnt have a thermostat.
Old Jul 16, 2003 | 08:38 AM
Stephen Max's Avatar
Re: Pictures of my Oil cooler/Mocal/Aeroquip fittings, etc.
Great documentation! I need to get off my butt and do mine.
One word of advice: It's better to use teflon paste on oil fittings. You fer shur don't want a bit of teflon tape to break off and get inside your oil galleries. Sounds like you were careful using it, though, so you should be okay.
Old Jul 16, 2003 | 09:08 AM
ejj's Avatar
ejj
Re: Re: Pictures of my Oil cooler/Mocal/Aeroquip fittings, etc.
I had problems with this with my Nitrous kit. The previous owner of the kit used tape, and some came off. Thankfully NOS kits have an in-line filter before the solenoids. The tape plugged that filter and prevented nitrous from flowing.
What kind of change in temps are you seeing? Were you seeing over 180*F that much? I know we've discussed this, but it takes a LOT of driving for me to get even close to 180.
Old Jul 16, 2003 | 09:14 AM
Jeff92se's Avatar
I'm needing a caw
Very nice. When you said Mocal, I thought you bought their hydraulic pump! Where did you get the hose from?
Old Jul 16, 2003 | 09:17 AM
Confused's Avatar
lots of lube and a bench vise.. i used a small circular motion to help sit it down.. lots of sweat and cursing. clamps - more to prevent ripping the hose
Originally posted by [maxi-overdose]
thx~
Old Jul 16, 2003 | 09:26 AM
Jer's Avatar
Jer
Kewl
Old Jul 16, 2003 | 01:58 PM
Stephen : I had my teflon paste but it was gone. I had to use teflon tape and I was very careful on wrapping them. thx for the advice.
ejj: I dont have a oil temp gauge. but it is hotter than my tranny cooler than. my tranny temp is around 150 - 160F.
Jeff: thx! I got my blue hoses at a local auto store. They have it in black or blue. I initially want to get a black hose for exit and blue for return. but the black hose was out of stock.
Confused : guess I was not as patient as you were. I gave up after couple try. I spent 5 minutes on it....drain all my energy and get a little break, then went back to work on it. I know if I kept doing this, I will pop a vein in my brain.
Hi Jer!
Old Jul 16, 2003 | 02:25 PM
JAY25's Avatar
BS, this is interesting to me. I may be PMing you because I may be removing my oil cooler and going with SS lines and I am going to mount the oil cooler lower below the radiator somewhere
Old Jul 16, 2003 | 09:47 PM
Originally posted by JAY25
BS,
did I say something wrong?
I think ejj started a thread in SC/TC forum about how to install a hose fitting to a metal braided line. hope that will help.
Old Jul 16, 2003 | 11:45 PM
araffio's Avatar
Should have picked up a Hayden 404 for $45 and installed it in 30 minutes, thats what I did...very simple
Old Jul 17, 2003 | 07:07 AM
Confused's Avatar
also available at summit
Old Jul 17, 2003 | 07:32 AM
isnt that just the tranny cooler itself? dont you still need sandwichplate adapter and fittings?
Old Jul 17, 2003 | 02:12 PM
araffio's Avatar
Mine came with everything I needed for the install, except enough hose. I bought more hose at the auto parts store and had the job done in 30 minutes...
Old Jul 17, 2003 | 11:05 PM
you are talking about tranny cooler? this is engine oil cooler that we are talking about here.
Old Jul 18, 2003 | 05:59 AM
Donkey®'s Avatar
wat
Donkey man: I agree with you. Stillen does carry some fine products. I didnt buy a stillen kit is because it doesnt have a thermostat. [/B]
Yeah, I alleviated that issue by installing an oil temp gauge.
Old Jul 18, 2003 | 06:44 AM
ejj's Avatar
ejj
That's doesn't help the oil get up to temperature faster, which is the point of the thermostat.
Old Jul 18, 2003 | 07:12 AM
Donkey®'s Avatar
wat
yeah, I was being sarcastic. But that is ok. Ignore my little : face.
Old Jul 18, 2003 | 08:11 AM
Redmax's Avatar
Redlinemax Owner
how much hotter does your oil temp get with boost
Old Jul 18, 2003 | 11:02 AM
JAY25's Avatar
[B]
You didnt say anything wrong this is all good info
Old Jul 18, 2003 | 05:21 PM
thx~
I saw you said "BS".....so I was wondering.
MaxLife17
Jun 27, 2019 01:37 PM
The Frye
Feb 3, 2019 08:34 AM
Cotozic
Jun 28, 2017 08:01 PM
kjlouis
Oct 3, 2015 05:29 AM
sdotcarter
Sep 2, 2015 09:53 PM
