Very loud road noise from right front wheel. Pls Help.
Old Jul 17, 2003 | 11:55 PM
Wisky97SE's Avatar
My Maxima has been making loud road noise at higher speeds (noticable at 35, louder at 55+), it is not a grinding or a screeching, it is as if my right front tire is solid rubber. My tires are not the problem however, I am guessing its the wheel bearing (1997 SE Auto with 88k miles and lowered suspension). Whenever I take left turns or make a left lane switch (car leans right), the noise is greatly increased for the moment that weight is transfered. When I take right turns (car leans left), the noise is gone all together and he car is more silent than if I were going straight.
Please help with any suggestions!
-Dave
Old Jul 18, 2003 | 12:47 AM
[maxi-overdose]'s Avatar
first thing I would do is to make sure all the wheel nuts are in place. happened to me recently that one of them was gone and it was making a strange continous noise.
Old Jul 18, 2003 | 05:35 AM
njmaxseltd's Avatar
Definately sounds like a wheel bearing.
Old Jul 18, 2003 | 09:19 AM
Bryan H's Avatar
wheel bearing
Old Jul 18, 2003 | 09:30 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
Re: Very loud road noise from right front wheel. Pls Help.
-Dave
That's your wheel bearing talking to you. It's saying "If you don't replace me soon, I'll really screw you over when you need me the most!"
Yeah, or something like that...
Old Jul 18, 2003 | 10:04 AM
DARHAW-MAX's Avatar
Well, that answers my question as to what is going on with my newly aquired '92SE. I figured it was the wheel bearings, but I was not really sure. Either way, I am going to replace both lower ball joints, both outer tie rod ends, and both axles. As much as I hate to do this, I will have the dealer do the front bearings since they need to be pressed into the baffle plate.
Darien
'92 SE, 5spd (project car)
'94 GXE, Auto
Old Jul 18, 2003 | 07:19 PM
Wisky97SE's Avatar
Thanks everyone! I brought it to the shop and it turns out my right rear wheel bearing is totally destroyed. I am excited about driving my car once I get it back, but I am car-less for a couple days. I assume hard turning / hard bumps accelerate the wear to the wheel bearings - correct?
Old Jul 19, 2003 | 11:33 AM
sean96SE's Avatar
Like everyone has said, definitely sounds like the wheel bearing. just be careful with the stealerships...
http://forums.maxima.org/showthread....hreadid=234077
I'm sure it doesn't happen often, but it just happened to me and i'm pretty bummed. At least ask for them to save you the bad part, it couldn't hurt. later
Matt93SE
May 24, 2019 02:58 PM
boomerbrian
Nov 8, 2015 05:10 PM
maxinout93
Oct 27, 2015 01:29 PM
KGMtech
Aug 18, 2015 09:21 AM
kirkhilles
Aug 8, 2015 10:53 AM
