Engine Swap Complete! *pics*
#44
Originally posted by johnvt1111
i noticed you had the mevi, but what's the difference in the engines.....what were the differences in the new engine and the old?
Originally posted by sryth
I'm no expert, but isn't it bad to have your engine's weight supported (even partially) by your clutch pressure plate?
#45
40 hrs...damn good job!!
Glad everything worked out for you! Is stock compression supposed to be 175? I had 170 on most cylinders but 2 (like 167 or 168)...I just hope the engine holds and that I don't have to go through what you did, although that must have been quite a learning experience!
#46
I'm happy with 175 though.
#47
Originally posted by ejj
Yeah, it would be. What are you refering too? When the engine was hoisted the strap was putting pressure on the bottom of the engine-tranny housing. The pressure plate wasn't supporting the weight of the engine.
#48
It must have been the angle, then. It seemed as though the strap was running over the pressure plate in one of the photos.
The pressure plate was just being pinched against the flywheel, which is ok.
Finkle
09-27-2015 09:53 PM
Team STILLEN
08-10-2015 04:29 PM
