clutch tools
Old Aug 4, 2003 | 08:02 AM
maxdrvr847's Avatar
clutch tools
when replacing the clutch, anyone have any tricks to get the pilot bearing out and also to hold the flywheel so you can get the bolts loose to remove it?
I know there is a bearing puller and a holder for the flywheel, but who has done it without getting those tools?
Old Aug 4, 2003 | 08:19 AM
ejj's Avatar
ejj
You can get the bearing puller and slide hammer at AutoZone to get the pilot bearing out.
To hold the flywheel you can have someone use a breaker bar on the bolt in the center of the Crankshaft pully on the other side of the engine.
Old Aug 4, 2003 | 10:51 AM
Jeff92se's Avatar
I'm needing a caw
Or use airtools to get the flywheel bolts off. That's the easiest way. You can buy a tool that holds it or use a big screwdriver to keep it from moving. You don't need a puller to get it off. Just wiggle it off or LIGHTLY tap it from each side to jiggle it loose. Upgrade! Upgrade! Upgrade to the Fidanza! hehe
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
