tranny whining while engine braking
Old Aug 4, 2003 | 06:10 PM
Nismo's Avatar
5speed- Is it normal to hear a whining noise while engine braking in 1st and 2nd gear? then again my tranny only has like 2 quarts of fluid left but just wondering.
Old Aug 4, 2003 | 06:39 PM
sryth's Avatar
Mine did this right before a major leak at the input shaft. Why are you down to 2 quarts of fluid? Do you have a leak?
My whine was caused by bad mainshaft bearings.
Old Aug 4, 2003 | 07:41 PM
young1976's Avatar
Re: tranny whining while engine braking
ever hear gears whining because of low lubrication? I would say your gear box is doing the same thing. A friend of mine had an Isuzu Amigo and one snow storm he engaged 4wd and locked the front hubs. It whined like crazy. He got back from the shop a week later and said the diff had little fluid left. Wonder where it went...
Old Aug 4, 2003 | 08:36 PM
Nismo's Avatar
im leaking because I have mysterious leak comming out of my passanger side axle. I guess its from the gears being not lubes. hope so
Old Aug 4, 2003 | 09:44 PM
sryth's Avatar
There ya go...it sounds like you have a failed differential bearing. That would explain the whine. Now prepare to pay lots of money (or sweat) to have it fixed. I did a mixture (removed the tranny myself, had a shop do the bearing R/R).
Old Aug 4, 2003 | 11:04 PM
Nismo's Avatar
well I dont know since I had the tranny checked out internally before I put it on and also I think its whining because theres not enough fluid in there. theres no play in the axles so I really dont know why its leaking.
Old Aug 4, 2003 | 11:26 PM
sryth's Avatar
There's no play in the axle? Hmm...maybe it's just a bad seal, then.
Old Aug 4, 2003 | 11:35 PM
Nismo's Avatar
we already tried 2 new seals and 2 axles (dealer installed both seals and 1 axle) so this is why were so stumped. dealer mechanic says it looks like the axle is going in at an angle and pushing against the seal.
Old Aug 5, 2003 | 12:00 AM
sryth's Avatar
Sounds like the bearing...check the play in the bearing.
pktaske
May 6, 2016 07:49 AM
BkGreen97
Apr 2, 2016 05:47 AM
pktaske
Sep 4, 2015 08:40 AM
A32goldylocks
Sep 2, 2015 06:39 AM
Lowered_a33
Sep 1, 2015 07:49 PM
