Help... My Car Idles At 400rpm...
Old Aug 10, 2003 | 04:50 PM
brownsvillemax's Avatar
i dont know what the heck is causing it but my car is idling at 400rpm, ive got significant horsepower and throttle response loss, compresion loss, and my ecu is throwing MAF and IAC codes. ive checked the maf and it is workin fine and i cleaned out the iac valve and it is still messing up and the check engine light came back on can anyone help me, what is causing it and how can i fix it..!!! my mods are warpspeed y pipe, catback exhaust and obx intake.
Old Aug 10, 2003 | 06:46 PM
slizan99's Avatar
how did you check the MAF?
Old Aug 10, 2003 | 08:16 PM
ny96max's Avatar
go to Nissan....
Ant
Old Aug 10, 2003 | 10:59 PM
if the MAF is out it wont rev past 2500rpm and if it is malfunction or about to go out u can tap it with any metal object and if it is messin up the car will shutdown... ive seen it done to all nissans many times. and plus i replaced it with the MAF on my friends max and nothing changed.
Old Aug 11, 2003 | 05:52 AM
njmaxseltd's Avatar
HP and Throttle Response loss = MAF on it's way out
Incorrect idle speed and the code for IACV = Your IACV is bad.
It's very possible that both of these items are bad. Replace the IACV first, clear the error and see if your car runs better. If you keep getting the MAF code back and your HP and throttle response is still poor, then your MAF is probably on it's way out.
Old Aug 11, 2003 | 06:16 AM
JerzMax's Avatar
When the MAF sensor is out and you rev, the rpms just drop, what does that mean?
Old Aug 11, 2003 | 07:26 AM
njmaxseltd's Avatar
It means your ECU has no clue how much air your getting.
Old Aug 11, 2003 | 08:06 AM
JerzMax's Avatar
Does that mean I need to replace my ECU? I hope not.....
Old Aug 11, 2003 | 08:13 AM
njmaxseltd's Avatar
No, your MAF sensor needs to be replaced.
Old Aug 11, 2003 | 08:17 AM
JerzMax's Avatar
I checked the voltage on the MAF sensor I got about 11-12 volts, that means it's working fine right?
Old Aug 11, 2003 | 09:07 AM
JerzMax's Avatar
If the MAF and sensor are good, what should happen when the sensor is out and you rev? For me, sometimes it wouldn't go past 2.5rpms and sometimes the rpms would just drop.
Thanks...
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
doobadoo
Aug 15, 2015 06:43 PM
Maxboy23
Aug 11, 2015 11:59 AM
