Painted Calipers and installed brake stuff w/pic!
Old Aug 10, 2003 | 08:23 PM
MAXimumHP's Avatar
Painted my calipers this weekend. Didn’t want to go too flashy like blue or red, but wanted to add a little touch so I painted them black with Silver Nissan Lettering on them. Turned out pretty decent actually. Most of the pics I took of the process turned out like crap so I’m just posting one below for now.
I also Installed:
Brembo slotted and dimpled rotors
Metal Master Pads
Stainless Lines
Synthetic Brake Fluid
I did get the pressure brake bleeder to work with the 4th Gen yellow cap. Couldn’t seem to get it to hold pressure on it’s own, but I added a few clamps to add some holding pressure and it worked fine. It was very handy for bleeding the brakes. Definitely worth the hassle to make one.
The Brake feel is nice. They seem more responsive, but they are barely broken in yet so I have yet to see how they are under more heavy use.
Old Aug 10, 2003 | 08:44 PM
Dave Holmes's Avatar
Looks sharp. Stupid question, but how did you do the lettering? That's the first Max I've seen with "Nissan" on the calipers. Did you make a stencil and spray?
Dave
Old Aug 10, 2003 | 09:08 PM
bonzelite's Avatar
nice. very sharp and simple, yet goes far. how did you get the decal on there?
Old Aug 10, 2003 | 10:27 PM
madmax97's Avatar
How long did it take you? How long you leave to dry, number of coats, did you sand it down and just bag off areas ? thank
Old Aug 11, 2003 | 06:11 AM
Bluesbrekr's Avatar
Doctorate in Detailing
That looks really sweet, Eric!!
Old Aug 11, 2003 | 07:06 AM
HuliganRS's Avatar
I like!!!
Old Aug 11, 2003 | 07:10 AM
MAXimumHP's Avatar
Here's The process I used:
Painted entire calipers Black using 2-3 coats of 500 degree engine paint. Then I got special stickers made from a local auto trim detail shop. The material is meant to be used as a mask and is low tack (low stickiness). They cut out the "stencil" using a vinyl cutter. It's applied just like the maxima.org stickers except it's the negative image. I then Mask off everything else and paint the lettering with "Aluminum" (silver color) engine paint. I used 2 coats. I left the black dry for an hour, which was not quite long enough. I did pull off some black removing the masks. Nothing I couldn't touch up though. I then use a clear coat engine paint and put on about 3 coats. It adds depth and really makes them shine. This is actually the second time I did something like this. Pretty easy, but time consuming. It took me all weekend. Friday night to jack the car up and remove the wheels and calipers. Saturday to prep and paint, plus for me, install the new lines (worked till about 4 in the afternoon) Then Sunday about 4 hours of re-installation and break-in. It could almost be done in one day, but I don't like to handle the calipers for a while after painting. They scratch and chip easily before the paint is cured.
Thanks to Jeff92se on this thread for helping me with the pressure bleeder.
And Bluesbrekr for helping me prep the calipers for painting.
Old Aug 11, 2003 | 07:46 PM
00MaxSE's Avatar
Pointy Elbows
Damn, that's a lotta work. But it does look sweet! Love that lettering.
Old Aug 11, 2003 | 07:50 PM
Nismo's Avatar
I say have a GD for your stencil stickers, what do you say??
Old Aug 12, 2003 | 10:59 AM
aznsap's Avatar
wow that looks good. did you completely remove the calipers from the car? if so, did you just let the brake lines hang or what?
Old Aug 12, 2003 | 12:59 PM
white95max's Avatar
Looks really good Eric. I haven't seen any calipers with the "NISSAN" on them before. Good work.
Every time I see painted calipers it makes me want to do it. Then I remember that I have to save my $ cuz I'm moving out in a week.
Old Aug 12, 2003 | 01:10 PM
MAXimumHP's Avatar
Any sign shop can make them, but I could get a bunch made and sell them if there is some interest. They would be cheaper then probably.
Old Aug 12, 2003 | 01:20 PM
MAXimumHP's Avatar
I answered you question on another post a few days ago, here's what I said in that post:
"Well, at first some comes out, but does not shoot out. it kind of dribbles out like a leaky faucet when you disconnect the lines. I left the lines hooked up and zip tied them to the spring so they don’t drip. That has worked for the last day and a half for me."
I completely removed mine, but it's not necessary. You could leave the line hooked up and just remove the caliper from the spindle.
Old Aug 12, 2003 | 02:35 PM
Capital15's Avatar
Pretty!! Makes me want to re-paint mine. Good job!
Old Aug 12, 2003 | 03:04 PM
Jeff92se's Avatar
I'm needing a caw
No problem! You should take pics of the pressure bleeder and the cap. I'd like to see it.
Bleeding is so easy. Just pump it up, loosen the bleeder screw and sit down on your **** for a few minutes.
Old Aug 12, 2003 | 03:38 PM
MaxMafia
Whoa...I like it!!
Old Aug 12, 2003 | 06:17 PM
maximaseefu's Avatar
hey that looks really clean and original.....wouldn't think that a stencil could look that clean. great work.
Old Aug 12, 2003 | 07:35 PM
MAXimumHP's Avatar
Jeff92se,
I did take some pics, some didn’t turn out too well though. When I’m not so busy I will put up more info and pics on my homepage.
It is super easy. Now that it’s so easy I may actually change my brake fluid every couple years or so.
Maximaseefu,
It isn’t the cleanest edge. Not a perfect line because the casting is uneven so you get some not so perfect lines, but it is a brake caliper so it’s not like you get down on your hands a knees and check them out too often. Most people just look down, and they look fine from that distance.
Old Aug 13, 2003 | 03:44 AM
kingrukus's Avatar
no more maxima...
That looks good.
Old Aug 13, 2003 | 12:09 PM
ny96max's Avatar
Re: Painted Calipers and installed brake stuff w/pic!
that Nissan logo looks a lil too big for the size calipers we have, otherwise its definitly unique!
Ant
Matt93SE
May 24, 2019 02:58 PM
rbuswell
Nov 17, 2016 04:54 AM
homeyclaus
Sep 3, 2015 06:15 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
RealityCheck
Aug 5, 2015 06:18 AM
