How important is O2 sensor?
I just installed the Apexi cat-back on my '97 and there was no hole for my O2 sensor behind the cat. I have it wired out of the way just above the pipe right now. No check engine light. I was wondering if I even need it. What exactly does it do and does it affect fuel/air mixture or the ECU? Anybody have some tech knowledge on this? Thanks.
Originally posted by Daniel B. Martin
The rear Oxygen Sensor monitors the performance of the main Catalytic Converter. It has no influence on the air/fuel ratio. However, I would have expected the Check Engine Light to go on. Don't be too surprised to see it go on in the next few days.
Yes, but...
Originally posted by Weasel
Is there a way to fool the car into thinking the O2 sensor is there and working? [/I]
A "savvy" electrical engineer could measure the signal coming from a healthy rear Oxygen Sensor and build a circuit which generates that signal. It is a sinusoidal waveform which varies between a low in the range of 0.0 - 0.3 vdc to a high in the range of 0.6 - 1.0 vdc. I don't know the frequency, but believe it to be low (10 hz or less).
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
