Paint Chips turning into rust spots
Old Aug 12, 2003 | 11:58 AM
MAX2000JP's Avatar
I was doing a little maintence on my car today and came across quite a few paint chips that have turned into rust spots. My car has 51k on it and has many paint chips due to Nissans poor paint. I am affraid that when the winter comes, many more of the chips are going to turn into rust spots. Does the Nissan Corrosion Warranty cover this? Anyone else notice this happening to their cars?
Old Aug 12, 2003 | 12:00 PM
ericdwong's Avatar
You wont get nissan to pay for jack. As for the paint rusting, well thats nissan quality for you. The only thing the rust thru warranty covers is if it rusts thru from the inside. Otherwise you're outta luck.
Old Aug 12, 2003 | 12:03 PM
deezo's Avatar
Re: Paint Chips turning into rust spots
I broke out my dremel this weekend to sand out those rust spots and touched them up with the Paintscratch paint marker until I can repaint the front of my hood. Dremel is the shyte!
Old Aug 12, 2003 | 12:06 PM
Albertt's Avatar
Re: Re: Paint Chips turning into rust spots
After living in CT for 4 years, my hood is riddles with rusty chip spots. What attachment did you use with the Dremel?
Where can one buy a Paintscratcher marker and does it match the specific paint name?
thanks
AL
Old Aug 12, 2003 | 12:12 PM
deezo's Avatar
Al,
www.paintscratch.com
The dremel bit number is 953 used at speed number 6.
Old Aug 12, 2003 | 12:35 PM
spirilis's Avatar
I've seen Turtle Wax selling some kind of paint marker/wax stuff at Walmart. Does that work just as well?
Old Aug 12, 2003 | 01:52 PM
Albertt's Avatar
Al,
Thanks...
Is the paint easy to apply? Is any wet sanding necessary?
#953 Aluminum Oxide Grinding Stone
I can't picture myself using it where I won't walk the bit all over the place and make more scratches.
AL
Old Aug 13, 2003 | 05:14 AM
deezo's Avatar
User is lightly and keep control of your hand. I just used a circular motion when I sanded the rust spots and no problems.
The paint is the best I've used. Way better than Nissan paint.
LtLeary
Sep 14, 2015 12:33 PM
16_SR
Sep 9, 2015 07:14 PM
Jamie Bowen
Sep 6, 2015 09:59 PM
sdotcarter
Sep 2, 2015 09:53 PM
