Lift Points for Hydraulic jacks
Old Aug 13, 2003 | 12:14 PM
Smokin' X-press's Avatar
Well I just bought one a couple days back cuz it's a lot easier to use than the stock ones, but can anyone tell me where to position this to lift the front and rear wheels.
Thanks...
Old Aug 13, 2003 | 12:23 PM
njmaxseltd's Avatar
Use the factory jack points.
You can use the main support beam up front under the engine to lift the whole front end up.
You can also use the rear beam to get a rear wheel off the ground without lifting the chassis.
Old Aug 13, 2003 | 12:30 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
I used to use the factory jack points too, they just got all crumpled after so much usage.... What I do now is place the cradle directly BEHIND the factor jack point - towards the middle of the car - that point is still reinforced. The best way though is how tom said it... use the motor support beam...
Old Aug 13, 2003 | 12:32 PM
Thanks guys!!!
Old Aug 13, 2003 | 03:47 PM
sryth's Avatar
As I said in an earlier post...do NOT use the "beams" that run up and the length of the car or you will be very sorry. My floor pan is totally crushed because I thought those "beams" were supportive enough.
Do yourself a favor and use the ones njmaxseltd suggested.
my03maxima
Jul 28, 2024 07:40 AM
litch
123
Jan 4, 2024 07:01 PM
gigabyte
Jan 6, 2017 06:05 PM
magiconthetire
Oct 26, 2015 09:03 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
