hitting 80k soon what to do ?
Old Sep 16, 2000 | 12:15 PM
amixam69's Avatar
ok.. coming up on 80k miles on my 96... what is there to do at this time.. fluid flushes ? more expensive synth oil ?
/????? basically...
amixam69 <= NO clue
Old Sep 16, 2000 | 03:42 PM
LuvSpeed
well other than regular and full maintenance there is only one thing that i personally think is a good idea to do when a car is getting older. There is no like researched proof for this but i am quite sure it is right. When the engine ages friction take off little shaving of moving engine pieces. Oil helps prevent this but it still happens. So as the car gets older it could use extra protection from the oil to protect the larger holes that have been created betweent the moving parts from the aging of the car. This is why i recommend thicker oil for an older car, perhaps a 10W-40 if you use 5W-30 or something like that. The thicker oil will be able to fill the larger spaces an old engine has better than a thin oil.
Old Sep 16, 2000 | 03:53 PM
JJW95SC's Avatar
I believe that 75k miles is the most recent schedule maintenance interval...
...so you should change your oil and filter, check hoses & belts, and check your spark plugs. A tire rotation may be in order, top off your fluids and that should do it!
Jim
Old Sep 16, 2000 | 06:12 PM
JMax2K's Avatar
Make sure you have your timing belt checked. My friend has a 2nd gen (1988). only had 90K miles on it (mind you this was just last year), mint condition, I kept telling him to get the timing belt checked, he kept forgetting. I was with him when it snapped...
He has a brand new engine in it now
D Mason
Jun 21, 2016 04:43 AM
BkGreen97
Apr 2, 2016 05:47 AM
captchaos
Mar 15, 2016 12:18 PM
doctorpullit
Dec 12, 2015 09:39 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
