ARP Head Stud Part Numbers
Mardi got this started, but here are the part numbers you need if you want head studs from ARP. I should have them within a week or so. I'll post updates.
Studs - ATP 5.200-1LB
Nuts - APN12-1
Washers - APW1316N
SGP Racing in TX should be putting together a head stud kit and also a main kit for us. I'm not sure when the mains will be available.
www.sgpracing.com
Nuts - APN12-1
Washers - APW1316N
www.sgpracing.com
Originally posted by ejj
What's the point of using this style head studs? Just stronger? I'd imagine they'd be easier to work with.
What's a set cost?
What's a set cost?
What's a set cost?
What's a set cost?
I'm not 100% on pricing, but the stud kit should be around $250 but I don't know about the main kit.
Originally posted by MardiGrasMax
factory bolts are made to stretch, "torque to yield", for mass production ease. Factory bolts under high cylinder pressures will stretch and let the cylinder head "pop up" and blow the gasket seal. These are stronger and will not stretch.
Originally posted by SR20DEN
I still want to know who's been blowing head gaskets. And does the FSM really call for torque to yield? I could use SR bolts over and over again and never had this problem.
Just got off the phone with ARP
the nuts are 1.60 each
The washers are .66 each
The head studs are 7.76 cents
We need 10 So the grand total for the whole set is $100.20
So why is sgp racing sselling the set for $400.?
Ten?
We need sixteen...
$1.60 x 16 = $25.60
$0.66 x 16 = $10.56
$7.76 x 16 = $126.16
Total = $162.32
I think the set that SGP is selling includes the mains also.
Originally posted by MadMax95
The nuts and bolts that hold the rods to the crank...
MR2 T'd
07-09-2021 05:06 AM
