Applying 30 Ft. Lbs Of Torque W/out A Torque Wrench...
Old Aug 21, 2003 | 08:59 AM
zemp68's Avatar
I JUST GOT A FRONT STRUT BAR FOR THE MAX AND IT SAYS TO TIGHTEN IT TO 30 FT LBS WITH A TORQUE WRENCH. ANYONE OUT THERE KNOW APPROXIMATELY HOW FAR TO TIGHTEN THESE BOLTS WITHOUT A TORQUE WRENCH?
Old Aug 21, 2003 | 09:01 AM
ejj's Avatar
ejj
I get them good and tight, then about a half turn more.
Old Aug 21, 2003 | 09:03 AM
zemp68's Avatar
so basically, it's pretty tight, not loose at all? they say you want some give to the bolts...
Sprint's Avatar
tighten it till your ***** tingles.. thats 30ft lbs.. when your viens hurt thats 60 ft lbs.. when your eyes buldge out.. thats 120 ft lbs
Old Aug 21, 2003 | 09:04 AM
zemp68's Avatar
that's the human torque scale, huh?
Old Aug 21, 2003 | 09:06 AM
Lordrandall's Avatar
Just go rent a torque wrench, it's free.
Old Aug 21, 2003 | 09:07 AM
zemp68's Avatar
from like autozone or where?
Old Aug 21, 2003 | 09:11 AM
Yes, like Autozone. Give them a call.
Old Aug 21, 2003 | 09:13 AM
zemp68's Avatar
ok, thanks a lot!
Old Aug 21, 2003 | 09:25 AM
soundmike's Avatar
Very sound, Mike
30 ft. lbs. isn't a lot really, i tightend the nuts on the wheels with as much force as i could get on it so i could reach the 80ft.lbs. requirement.
Later on i double checked it with a torque wrench and i got it on right, probably too tight even.
Sprint's Avatar
yes
Old Aug 21, 2003 | 09:27 AM
ejj's Avatar
ejj
An exact torque setting on the strut tower nuts isn't really required. Just getting them "tight enough" will do just fine.
I would invest in a torque wrench though. If you're going to work on your car you really need one.
Old Aug 21, 2003 | 09:29 AM
zemp68's Avatar
Sounds good. I was told by a mechanic that torque wrenches were extremely expensive????
Old Aug 21, 2003 | 09:30 AM
clee130's Avatar
If you consider $25 extremely expensive ... then yes, they are.
Old Aug 21, 2003 | 09:32 AM
soundmike's Avatar
Very sound, Mike
Got mine for a very expensive price of $14 from Autozone. Man, Clee you're rich
Old Aug 21, 2003 | 09:36 AM
zemp68's Avatar
man, that's expensive! lol. that mechanic was full of it.
Old Aug 21, 2003 | 10:33 AM
jim90gxe's Avatar
Yes a good accurate torque wrench can cost a bit.But any real mechanic will tell you if you buy a cheap tq wrench you might as well torque by feel.
Old Aug 21, 2003 | 10:35 AM
spirilis's Avatar
1/2"-drive torque wrench'll cost you about $25-30 for the typical autozone type (Craftsmen might cost $70-80)
Don't overtighten those strut tower nuts, you can break the strut plate studs off easily... definitely buy a torque wrench if you're in any doubt...
Old Aug 21, 2003 | 10:53 AM
zemp68's Avatar
ok, i just tightened the bolts until snug, then a 1/4 turn after that...i should be safe until i get the torque wrench, but good god, that makes a world of difference on the highway curves!!!!!!!! SOLID!
Old Aug 21, 2003 | 10:57 AM
ejj's Avatar
ejj
You'll be fine. I don't use a torque wrench on most of the stuff on the car.
Old Aug 21, 2003 | 10:58 AM
zemp68's Avatar
awesome. thanks!
Old Aug 21, 2003 | 11:05 AM
Jeff92se's Avatar
I'm needing a caw
Only here on .org can it take 2 pages to explain how to torque some FSTB nuts to 30ftlbs. Holy crapola.
Old Aug 21, 2003 | 11:06 AM
zemp68's Avatar
lol
Old Aug 21, 2003 | 11:10 AM
ejj's Avatar
ejj
I'm still on the first page!
Old Aug 21, 2003 | 11:22 AM
gtr_rider's Avatar
192.168.1.1
Old Aug 21, 2003 | 11:40 AM
spiff56747's Avatar
30 lb/ft is not very tight at all. i would say if youre using a regular size ratchet, you get to 30 lb ft before you start really struggling with it. its basically the minute you feel any real resistance, just stop. at least thats what my $10 dollar torque wrench tells me
Old Aug 21, 2003 | 12:28 PM
clee130's Avatar
I like to spoil myself from time to time.
Miket2006
Mar 1, 2021 03:55 AM
doctorpullit
Apr 23, 2017 05:35 AM
msellas
Sep 23, 2015 09:16 PM
mpbclutch33
Sep 21, 2015 01:54 PM
