JIC Coilover Owners.. in here
Old 08-27-2003, 08:38 PM
  #41
MaxRPM's Avatar
Various pics of my car with JICs on a racetrack (Mosport).
Click Here
MaxRPM is offline
Old 08-27-2003, 08:53 PM
  #42
thebigsadler's Avatar
will you people take your cars off grass.. its very deceiving.
someone has to have the time to slam these bishes please
thebigsadler is offline
Old 08-27-2003, 09:41 PM
  #43
Bulldawg's Avatar
that is the point . deception is my friend
Bulldawg is offline
Old 08-27-2003, 11:23 PM
  #44
drewm's Avatar
I'm suprised he hasn't come in here himself to say so, but matthel is probably slammed close to all the way down on his JICs, it shows in some of the meet pics (look for the blue one in the links on the right side of the page):
http://norcal.maxima.org/
drewm is offline
Old 08-28-2003, 01:42 AM
  #45
Needs non-Maxima Friends
nismo2020's Avatar
Click Here
hot pics.. love the one of the porsches chasing you.
nismo2020 is offline
Old 08-28-2003, 07:18 AM
  #46
i dont think turtle max is slammed all the way, there is still some wheel gap in there and the 17s are slightly cheating.. i am that low on my crappy gcs's.
Old 08-28-2003, 10:08 AM
  #47
PCGuRu2K's Avatar
I loved my JIC's.. Had my ride with no finger gap. Set on 10/9 on the stiffness.. There was absolutely no noise when you turned or went over bumps. Ride was nice and smooth. But since I dropped it soo much and was on a high setting you can feel the bumps. But I like a stiff ride anyways. You can always slam the car and set the settings to like 7/7 which is average..
PCGuRu2K is offline
Old 08-28-2003, 10:43 AM
  #48
Sprint's Avatar
Sprint is offline
Old 08-28-2003, 10:53 AM
  #49
Blu
the tits
Blu's Avatar
Originally posted by SprintMax
Blu is offline
Old 08-28-2003, 11:47 AM
  #50
matt calder's Avatar
Maybe at Nopi I will.
matt calder is offline
Old 08-29-2003, 10:50 AM
  #51
PCGuRu2K's Avatar
PCGuRu2K is offline
Old 08-29-2003, 11:20 AM
  #52
Rice Boy in Denial =)
Y2KevSE's Avatar
http://www.boostedmaximas.com/y2kevs...es/car2/02.jpg
http://www.boostedmaximas.com/y2kevs...es/car2/06.jpg
http://www.boostedmaximas.com/y2kevs...es/car2/09.jpg
The car can probably go down another 2" to 2.5", but then the camber plate would be riding on the bump stops.
Need some answers:
What is your front wheel gap?
Do you get any noise while turning?
Any bouncing feeling on rough roads?
Is it rough over bumps?
What is your soft/hard setting on front and rears?
add anything else you feel like adding
1 Asian finger gap in the front
0 finger gap in the rear
No noise at all, you will need to preload to springs as mentioned... just don't preload it too much.
Stiff at 10/10. That setting is not for the faint of heart.
Yes, rough over minor bumps, but a HUGE difference over bigger bumps. The ride feels almost like stock over big bumps and dips.
Y2KevSE is offline
Old 08-29-2003, 11:36 AM
  #53
Sprint's Avatar
ok you explained in the "other" forum how to preload the spring.. can you give a detailed explanation again please
Sprint is offline
Old 08-29-2003, 12:33 PM
  #54
Y2KevSE's Avatar
From the "other" forum:
"Preload the springs so that they won't move when you push and pull them, but don't preload so much that the springs are seriously compressed."
assuming you adjusted the strut body so the car is at a height you're happy with when lowered.
1) Turn spring perch up until it touches the spring... keep turning until the spring hits the camber plates
2) Keep turning until the spring doesn't move when you give it a good budge. Maybe ~3 full turns or so?
3) Repeat on other side.
Y2KevSE is offline
Old 08-29-2003, 12:36 PM
  #55
Sprint's Avatar
so you adjust the hight from the lower red adjuster? is it the higher up you adjust the higher the wheel gap gets?
Sprint is offline
Old 08-29-2003, 01:03 PM
  #56
Y2KevSE's Avatar
Nope... you adjust the height with the strut body. That's because you want to have the most suspension travel as possible. Believe me, you will not need to lower the car via adjusting the spring perch. I even had to raise the car up because I over did the lowering on the strut bodies. If I jack the car up off the ground, the wheel gap is about 2-4 fingers.
The only true way to figure out the height is to test your adjustments.
Y2KevSE is offline
Old 08-29-2003, 01:08 PM
  #57
Sprint's Avatar
huh? what do you mean ajust via the strut body? where? i am confused now
quick grab matts pic and tell me how real quick
tell me what do i turn to adjust the height
http://images.cardomain.com/member_i...19_62_full.jpg
Sprint is offline
Old 08-29-2003, 01:09 PM
  #58
keving beat me too it.
Sprint, you adjust the part that is attached behind the brake with the 2 bolts. Undo those 2 bolts and start spinning that bottom piece around till you get the height you want.
Right below the lower red adjustment thingie.
Old 08-29-2003, 01:13 PM
  #59
Sprint's Avatar
holy ****.. totally missed that .. i got it the height i like now.. but i wanna know for when i got to raise it back up for the winter
Sprint is offline
Old 08-29-2003, 01:15 PM
  #60
Y2KevSE's Avatar
Picture says it all:
Y2KevSE is offline
Old 08-29-2003, 01:17 PM
  #61
Y2KevSE's Avatar
Those are for the rears... but the same can be done to the fronts.
This is why you paid bling bling and waited forever for the coilovers.
Y2KevSE is offline
Old 08-29-2003, 01:18 PM
  #62
Sprint's Avatar
didn't i just ask you that you doofus.. and you said no?
i said do bring the lower red thing up.. and then screw the bottom to adjust the height.. you said no..
i was asking you if the more you screw the bottom up.. is the higher the car gets
Sprint is offline
Old 08-29-2003, 01:19 PM
  #63
Sprint's Avatar
don't remind me f a g boy
and now its taking forever to get them the way i want them
Sprint is offline
Old 08-29-2003, 01:21 PM
  #64
Dont listen to keving, he is stupid.
Old 08-29-2003, 01:27 PM
  #65
Y2KevSE's Avatar
Oh... you confused me.
Think about it this way, the more threads you see, the higher your car will be.
[B]
don't remind me f a g boy :mad :mad
and now its taking forever to get them the way i want them :mad
:mad
Dont listen to keving, he is stupid.:tard
Yo mama...
Y2KevSE is offline
Old 08-29-2003, 01:42 PM
  #66
Shiver me timbers.
maxfanfromohio's Avatar
Yo mama...
maxfanfromohio is offline
Old 08-29-2003, 03:08 PM
  #67
Sprint's Avatar
that doesn't make sense q u e e r boy.. are you telling me the more threads you see inbetween the red things is the higher the car will be?
thats BS.. i got tons of space between the red things and my car is 1 finger gap.. so you telling me if i had them closer i would be tucking fenders?
Sprint is offline
Old 09-01-2003, 02:56 PM
  #68
MAXIN's Avatar
It does make sense, you can have alot of space between the perches and still be dropped pretty low. (but in this case you may have too much preload). Put it this way, once adjust the preload with the first(larger perch) you then lock it in place with the second smaller perch, and you should never really have to touch those again. The lowest perch is what you use to adjust the height.
mad late:
1) 2 finger
2) I get an occasional pop or too but I think its my axles that keep coming loose for some reason. (doing this before the JICs...)
3) If the dips and bumps are deep enough it will kinda bounce, but I think i still need to adjust them. (too lazy)
4) On really hard bumps it doesnt seem to abosrb much. The impact transfers straight into the cabin. But it still maintains control. (again I may need an adjustment.
5) Currently on 13 Front/11 Rear. Its pretty stiff but for some reason its comparable to my old cattmans gen IIs so Im good......
MAXIN is offline
Old 09-02-2003, 02:50 PM
  #69
Fastest Fantasy Maxima Evar
IceY2K1's Avatar
Anyone able to bottom out on the bump stops?
IceY2K1 is offline
Old 09-02-2003, 03:03 PM
  #70
i will slam mine all the way when they get here this weekend.. as low as they will go, once i figure out all the adjustment factors you will see them bottomed out.
kev, do you have any more pictures of them installed and such?
Old 09-02-2003, 10:29 PM
  #71
Y2KevSE's Avatar
http://boostedmaximas.com/y2kevse/images/car2/01.jpg
http://boostedmaximas.com/y2kevse/images/car2/02.jpg
http://boostedmaximas.com/y2kevse/images/car2/03.jpg
http://boostedmaximas.com/y2kevse/images/car2/04.jpg
http://boostedmaximas.com/y2kevse/images/car2/05.jpg
http://boostedmaximas.com/y2kevse/images/car2/06.jpg
http://boostedmaximas.com/y2kevse/images/car2/09.jpg
Y2KevSE is offline
Old 09-02-2003, 11:33 PM
  #72
¿Hablas Español?
joaquink's Avatar
Re: Security gate at front door...
"In the ghetto
People, don't you understand
the child needs a helping hand
or he'll grow to be an angry young man some day
Take a look at you and me,
are we too blind to see,
do we simply turn our heads
and look the other way
Well the world turns
and a hungry little boy with a runny nose
plays in the street as the cold wind blows
In the ghetto
And his hunger burns
so he starts to roam the streets at night
and he learns how to steal
and he learns how to fight
In the ghetto..."
P.s. I have one too.
joaquink is offline
Old 09-03-2003, 07:06 AM
  #73
Y2KevSE's Avatar
"In the ghetto
In the ghetto
In the ghetto..."
The neighborhood is safe, but extra protection doesn't hurt. The few extra minutes it takes to break the door down will give me enough time to find a bat.
Y2KevSE is offline
BkGreen97
04-02-2016 05:47 AM
NewMax03
10-07-2015 08:27 AM
NismoMaxi02
10-04-2015 09:09 PM
JakeOfAllTrades
09-30-2015 03:16 PM
Garrettz459
09-28-2015 02:50 PM
Quick Reply: JIC Coilover Owners.. in here
