brake caliper overhaul
I'd like to overhaul my calipers. I've read the chiltons and want more info before I begin.
Or is it a better idea to just get a rebuilt caliper and exchange the core?
Jae
Jae
Courtesy sells the rebuild kit for about $22 per pair of calipers. Rebuilding a caliper just consists of replacing all the rubber parts and cleaning everything out really well. I'm going to do this soon as well. My right-front caliper is leaking fluid around the piston seal.
Originally Posted by Nismo
what are you trying to do? change the piston and seal?
mzmtg: so i'm looking for a caliper seal kit? For $22-33, should I just goto autozone and get a rebuilt caliper and return my core?
How difficult is it to change the seals and clean everthing? The chilton schematic looks like there's 20 parts to disassemble.
Jae
Originally Posted by ejj
If you're not confident in re-building your calipers, that would be the best bet. May cost you more, but you don't want to mess up your brake system.
Its not really that hard. Just keep track of what was where when you take it apart, and put them back together the same way.
Time is important--why waste it? Now my uncle wants me to turn off his service engine soon lamp because he doesn't want to pay the dealer (came on at 61k). I try to tell him, what part of my story don't you understand? I turned mine off 4 times and cleaned the EVAP thingy but eventually I had to go to the dealer anyway, and the car ran better after I did. My aunt understands but he just wants the light off and doesn't want to pay.
When popping the piston out, becareful if you are using compressed air. I shot the piston across the table doing this!!!!!!! It takes just a little air to pop the piston.
It depends on how much the rebuilt calipers are. It's not a difficult job.
Rear wheel calipers are much more expensive than front because of the ebrake mechanism inside. Dealer price: 275$ CAD: refund for core: app 100$.
I have a seized ebrake lever on the right side. Eventually I will have to change it. I am not planning on rebuilding a rear caliper because of all the internal parts involved.
Also if your going to use the ait compressor to take the piston out, make shure you put a piece of wood or a note pad in front of the piston or else you might scar the piston if it slams against the caliper or something else
Originally Posted by ivelweyz
Just take the caliper off the rotors and apply brakes. Have someone hold it as it pops. out...
Ok, I'll call around for the parts vs calipers. I have a feeling I'm going to buy the seals and do it myself since I'll be saving $ and I got all weekend to do all 4 anyways.
So no special tricks? Just disassemble, clean, reassemble? Any lubricating involved?
Jae
Apr 16, 2020 05:15 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
