Got pen ink stained on my door!!! (exterior)
Old Oct 1, 2003 | 01:50 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Well, a couple days ago at school a pen apparently bursted in my pocket, and when I went to open my car door, the ink from my hand (that was resting on the door got on the car. Now there is a little stained blotch that is copper in color. I tryed using car soap to get it off, didnt work. I scraped gently with my finger nail and it smeared it around some, but nothing really changed. What can I do to get this off??
Old Oct 1, 2003 | 01:52 PM
deezo's Avatar
3M Compound baby! Just wax afterward.
Blu's Avatar
Blu
the tits
80 grit sandpaper
Old Oct 1, 2003 | 01:53 PM
Craig Mack's Avatar
What is 3M compound? Some kind of tape?
Old Oct 1, 2003 | 01:54 PM
Craig Mack's Avatar
Originally Posted by blubyu2k2
80 grit sandpaper
not funny
SR20DEN's Avatar
VQ Wizard
Paint thinner
Blu's Avatar
Blu
the tits
wtf....you have got to be kidding me....
Old Oct 1, 2003 | 01:59 PM
deezo's Avatar
It's just rubbing compound. You can get it al Kmart or Walmart. You should definitely be able to get it at your local Autozone or Poop Boys.
Old Oct 1, 2003 | 02:04 PM
deezo's Avatar
Originally Posted by SR20DEN
Paint thinner
Now that's wrong...
Old Oct 1, 2003 | 03:48 PM
Cutler's Avatar
Jackhammer
Old Oct 1, 2003 | 03:52 PM
gtr_rider's Avatar
192.168.1.1
pepsi will take it right out
Old Oct 1, 2003 | 03:59 PM
Craig Mack's Avatar
Are you being serious?
Old Oct 1, 2003 | 04:07 PM
EteRnity059's Avatar
Boosted?....
Coke will work too. It's very acidic, some people use it to clean battery terminals.
Old Oct 1, 2003 | 05:20 PM
Craig Mack's Avatar
I know that. I know some rescue workers use cocacola to clean the blood off roads in traffic accidents. It's amazing how people can put that in their bodies...
anyways, so cola wouldn't damage my clearcoat?
Old Oct 1, 2003 | 05:32 PM
DanNY's Avatar
Ad·min·is·tra·tor
#1 way to get pen ink out...use rubbing alcohol.
it's safe on the paint...dab some on a clean cloth and blot it off. if u don't believe me write on your hand and get it off w/ alcohol..you'll see it'll just come out.
i'm serious.
also rubbing compound and waxes might smear the ink.
Old Oct 1, 2003 | 06:31 PM
PrinzII's Avatar
OG and counting...
a) Try a tar remover first
b) Try rubbing alcohol as DanNY said
c) if that doesn't work, try mineral spirits
Old Oct 1, 2003 | 07:10 PM
Y2KMaxGXE-R's Avatar
I'd vote against rubbing compound. 1st solution is a bug and tar remover, 2nd solution rubbing alcohol. 3rd solution is a paint thinner-be very careful with that.
Old Oct 1, 2003 | 07:25 PM
asu174's Avatar
Clay Aiken has fancy genitals
Sell your car and get a Camaro. That is really your only option at this point.
Old Oct 1, 2003 | 07:50 PM
Boosted?....
Do not use paint thinner, I stripped the H3ll out of my paint one time. I had to get the whole quarter panel repainted.
Old Oct 1, 2003 | 08:01 PM
DanNY's Avatar
Ad·min·is·tra·tor
it's called "paint thinner" for a reason.
don't know why 1/2 you guys are telling him to use that.
Old Oct 1, 2003 | 08:28 PM
maxfanfromohio's Avatar
Shiver me timbers.
Your best bet is a hammer and chisel. If that doesn't work, try goo-gone.
Old Oct 2, 2003 | 11:42 AM
nice95GLE's Avatar
OK all BSing aside the best way I know of to remove ink stains from a car exterior is
1. Lemon Juice (use a fresh lemon)
2. Hairspray (nothing to strong)
Those should work fine.
Good Luck
Old Oct 2, 2003 | 12:52 PM
Craig Mack's Avatar
LT1 or LS1? Z28 or SS? The black on black loaded '97 Z 6spd just didnt do it for me man.
Old Oct 2, 2003 | 12:57 PM
Jeff92se's Avatar
I'm needing a caw
Oven cleaner!
Old Oct 2, 2003 | 01:56 PM
DanNY's Avatar
Ad·min·is·tra·tor
Good Luck
not sure about lemon juice..
the reason why hair spray works is due to the alcohol content in it.
Old Oct 2, 2003 | 02:04 PM
gtr_rider's Avatar
192.168.1.1
Old Oct 2, 2003 | 02:46 PM
Craig Mack's Avatar
Well, I took DanNY's advise and used some rubbing alchohol. Worked like a charm. Thanks guys!
Old Oct 2, 2003 | 03:53 PM
DanNY's Avatar
Ad·min·is·tra·tor
Old Feb 5, 2016 | 04:30 PM
Kahnie77095's Avatar
The alcohol worked, but I'm hoping saturating a towel area and soaking it a bit does better than rubbing like I started, but out of the mass I had I only have two small areas left. I will get compound for those and get the rest out. Thanks all
Old Feb 6, 2016 | 04:12 PM
george__'s Avatar
After 13 years it finally came out?
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
BobTX10
Oct 7, 2015 08:43 AM
lrb6805
Sep 24, 2015 05:03 PM
