where should i point my subs?
Old Feb 15, 2001 | 04:11 PM
1Phat Max's Avatar
I just got a rockford 360a2 and 2 10" rockford subs with box with my factory bose
sytem!!! now my question what is the best way to point the box? should i point the
subs out or in and what is the differeces or pros or cons for where should the subs
be pointed. any help is appreciated.
Old Feb 16, 2001 | 08:50 AM
Synki's Avatar
In a Maxima, you would want to either fire back (towars trunk) or fire up. Normally i would always try to have them fire at an angle.. like towards the back/up. That sounds the best and distributes the waves. Since you seats dont fold down, you dont want them to fire there, it will muffle it and sound like crap. You would want it to fire towards the back where the waves can bounce back and make the sub sound louder and better. THis also allows you so push a bit more power. The waves are bouncing back and the sub will have a harder time bottoming out. Just what i have noticed from doing installs when i was at my local car audio shop.
Old Feb 16, 2001 | 05:53 PM
bullseye's Avatar
I thought subwoofers put out *omni-directional* bass sound. No matter where they point, you hear good bass sound. True?
I have a sub box enclosure in my trunk that can move around somewhat during very spirited driving. No matter which way the sub ends up pointing, the character of the bass sound does not seem to change a bit. Am I all wet, or what?
Please advise. Thank you.
Old Feb 17, 2001 | 12:41 AM
SWEETSOUND2001's Avatar
go to my install page in my sig. and get an idea.
Old Feb 17, 2001 | 04:02 AM
metallic97gxe's Avatar
Master Will
music type......
makes a difference..
front-rock,metal,country
rear-rap,hip,hop,bass,pop.according to some car mags..but I have seen many sub installs
I have tried it front and rear and I listen to ALL types of music and rear is how I have mine. To the front sounds bad unless you have a bunch of power your seat absorbs the bass waves and vibrations,firing up if you have a bunch of power over time your rear glass seal will go bad bass pounding up against that glass all the time. Towards the trunk rear facing the bass "doubles" back bounces off of the trunk for more power.
Old Feb 17, 2001 | 06:51 AM
Botos's Avatar
Towards the rear of the trunk is usually preferred, since you get an increase in sound from the reflection. It's also a good idea to bolt the box down so it can't roam around.
my03maxima
Jul 28, 2024 07:40 AM
gigabyte
Jan 6, 2017 06:05 PM
magiconthetire
Oct 26, 2015 09:03 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Redfox
Sep 28, 2015 10:41 AM
