when bleeding brakes with ABS , ignition stays ON or OFF ?
Old Oct 6, 2003 | 06:19 PM
nick's Avatar
Well my SS lines came in along with brembo blanks , nissan OEM pads
and speedbleeders - to make things easier.
Now I have one question - ( already searched ) for bleeding the brakes with ABS - does the ingition have to be ON or OFF, and are there any special instructions for bleeding brakes with ABS ?
Old Oct 6, 2003 | 09:04 PM
ivelweyz
I think it's on just like every other car. How can you even do it with it OFF, the brakes will be rock solid with 3 or 4 pumps of the pedal. When I did mine I had the car running...
Old Oct 7, 2003 | 04:06 AM
njmaxseltd's Avatar
I've never had a car running to bleed brakes? You don't need to have the power booster working to flush fluid through the system. Once you open a bleeder, the pedal will go right down to the floor very easily, even without assistance from the power booster.
Old Oct 7, 2003 | 04:19 AM
spirilis's Avatar
yeah... and you want that "rock-hard" feel to determine if they're bled properly
Old Oct 7, 2003 | 05:54 AM
Kashoggio's Avatar
off! before you do anything pump your brakes about 15 to 20 times to reduce the presure in the lines from the abs
Old Oct 7, 2003 | 08:12 AM
Bags's Avatar
VG Ridah's Biatch Hoe
Ignition does NOT matter... why???
THE BATTERY SHOULD BE DISCONNECTED
CREDIT - FSM
Old Oct 7, 2003 | 12:11 PM
nick's Avatar
cool - thanks for all the info !!!
Old Oct 7, 2003 | 12:17 PM
Jeff92se's Avatar
I'm needing a caw
Put this reference into your favorites
http://www.cybrrpartspro.com/Chilton...61CH09_10.HTML
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
