advance the timing... now what gas?
Old Oct 17, 2003 | 10:06 AM
virus99's Avatar
what is the min. octane gas i can go with?
my timing was advance to 17 degree
is octane rating of 91 okay or should i got with 93?
and if 91 is only avaliable should i buy octane booster to increase the octane?
Old Oct 17, 2003 | 10:09 AM
Cashj2002's Avatar
93 only!!!
Old Oct 17, 2003 | 10:20 AM
MrGone's Avatar
honestly, if there is no pinging or knocking, just use what you always use.
Old Oct 17, 2003 | 11:21 AM
Kevlo911's Avatar
Kevlo for President
91 is what the book says to use, so why waist more money if it won't help?
Old Oct 17, 2003 | 12:25 PM
D-sta's Avatar
Well I advanced my timing from 15 to 20 degrees and I was told just to use 93 or higher octane. These are the words from some members and the techs at Jim Wolf.
Old Oct 17, 2003 | 12:34 PM
Sprint's Avatar
how exactly did you advance the timing on your 99?
Old Oct 17, 2003 | 02:33 PM
virus99's Avatar
thanks for all the input i guess i'll be carrying around octane booster incase 93 gas is not avaliable thanks again .org peeps
Old Oct 17, 2003 | 03:16 PM
Kevlo911's Avatar
Kevlo for President
octane booster does nothing from what i read.
for sprint
Old Oct 17, 2003 | 03:27 PM
Quicksilver's Avatar
OT n00bs FTMFCSL
for sprint
Buy some toulene...don't use much of it though...
Old Oct 17, 2003 | 05:19 PM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
My stock timing was getting pulled in the summer heat even on 93 octane. When you're in heat soak conditions you need all the octane you can get. I would run the maximum pump octane that you can get at all times, but would not use octane boosters on a daily basis or anything like that.
Old Oct 17, 2003 | 09:14 PM
MrGone's Avatar
on my 93 VE, I am running 20* timing, and just installed a resistor for the knock sensor. I'm using Arco 93 octane and I'm not getting one single ping or knock and I drove the **** out of the car.
I was at a friends house, exact same setup, but he uses Chevron 93 octane, we could hit 17* but it would still ping.
I took mine up huge hills, lugged the crap out of it, etc. no pinging or knocking. Also our Durango pings when going up hills on Texaco, yet on Arco we can tow 3000lbs up that same hill and it still will not ping, using 87 octane from both companies.
Old Oct 18, 2003 | 04:41 PM
Sprint's Avatar
1234567890
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
ef9
Oct 4, 2015 08:43 AM
