Whatsup with rear trunk with OEM alarm?
Old Feb 18, 2001 | 07:36 PM
ericdwong's Avatar
My 97 SE has an OE alarm, and while it is armed, if I pop the trunk by remote or button, it doesnt go off... is it disabled or is there no alarm on the trunk at all?
Old Feb 19, 2001 | 12:33 AM
littledog's Avatar
If you open the trunk legally (ie, not by force), the alarm wouldn't go off. It would sound kinda weird if the alarm goes off when you press the button on the remote.
Old Feb 19, 2001 | 06:46 AM
Sonic's Avatar
I guess my alarm is retarded because my alarm does go off if I pop the trunk with the remote. I have to unlock the doors first, then pop the trunk. Can anyone think of a way of fixing this?
Old Feb 19, 2001 | 04:13 PM
Eric L.'s Avatar
Hmmm...that's wierd. Do you mean that the alarm goes off when you open the trunk with the remote keyfob, or the remote switch on the drivers door? If you open it via the switch on the door, then the alarm will go off. It should not go off if you use the remote control.
Old Feb 19, 2001 | 04:37 PM
Sonic's Avatar
Yup, the trunk opens with the remote when I press the trunk button on the remote, but then the alarm still goes off. I can only turn it off with the door unlock button.
Old Feb 19, 2001 | 08:21 PM
piopremier's Avatar
oem alarm
i got bumped in the back a few months back and now my remote doesn't work. anyone know if or where the sensor might be so i can figure it out. sometimes if im standing right next to the car it will work but not from any type of distance like before.
Old Feb 19, 2001 | 09:14 PM
edadams's Avatar
The latch mechanism has a switch located inside, check to see if it operates properly. I believe the switch also works the trunk light.
vingodine
45
May 21, 2016 12:46 PM
Former3G
Oct 26, 2015 11:34 PM
Huttig2009
Sep 25, 2015 03:31 PM
JoshG
21
Sep 4, 2015 09:04 PM
Hailstatejig
Sep 2, 2015 06:52 AM
