REAR beam bushings???
Old Oct 24, 2003 | 12:40 PM
mzmtg's Avatar
Minister of Silly Walks
I found the following write-up about getting new trailing arm bushings for the rear beam. Does anyone know where we can get custom bushings made? I havent looked at mine lately to see if they have large voids that could be filed with poly. Anyone else got any ideas?
I have been building and racing B14's for quite a while and have never quite been able to get all of the understeer out of the chassis and to make the car respond crisply to attempts to get it to rotate. I have gotten them to where they rotate slowly with bending the beam and with ridiculose spring and rear bar rates but they will still have terminal understeer if driven in a ham fisted manor.
The B14 is also sort of squirmy under trail braking and turn in and also has a vauge feeling in the rear while taking a set.
Well I was looking at the trailing arm bushings and noted that they were made of really gushy rubber and had large windows cut out in them for additional flex. I figured that these bushings were allowing the axle to walk around giving the unsecure feeling in the back and also decoupling the antisway bar and the torsion bar of the rear axle.I had Energy make me a set of urethane solid bushings to replace the rubber.
The results are oh my god! The car is now so responsive I spun it on the track on my first lap, just warming up the tires. The car was way too loose, a first for a B14. After some shock and tire pressure adjustment, it was a lot better but still quite loose and I managed to spin in the race when I had to take a turn off line to avoid spinning cars.
I feel that this will make a big breakthrough in B14-B15 handling, i just have to resort my car to take advantage of the better response but reducing oversteer a little. I am going to soften the rear bar and perhaps the rear springs.
These bushings are like going up 300 in/lbs in rear spring rate! They make a bigger difference in chassis balance than anything I have done so far. They also eliminate the squirm and weird feeling out back.
Energy should have them for sale soon. As a warning, although they should be nice on a street car, if you have an already on the edge tuned race car, its going to knock you into wild oversteer.
Mike
Note that when he talks about spinning, he is talking about a racecar that has already been extensively modified to reduce understeer. Also, he mentions that Energy will be producing these for the B14/B15. I wonder if those would fit our cars too.....
Old Oct 24, 2003 | 12:44 PM
Jeff92se's Avatar
I'm needing a caw
Nice idea! I would maybe get a boneyard set and start measuring up what you need. Then ask Energy if they have a similar set. Or drop some eurothane in there(ala motor mounts) and call it a day.
Old Nov 16, 2003 | 02:41 PM
mzmtg's Avatar
bump
Old Nov 16, 2003 | 03:09 PM
CullenJ76's Avatar
That's a great idea. I was actully underneath my car the other day and noticed that they were all flat on one side and cracked on the other half from what i could see. ES would probably do it, especially if we got some more people(serious interests)together, and they did them all at once.
Old Nov 16, 2003 | 03:55 PM
BEJAY1's Avatar
Conecarver
Yup, lots of Sentra owners are jazzed that Nismso finally came through on these for their cars.
http://www.nissanperformancemag.com/...mo_suspension/
I already wrote to Voyt @ Energy asking for these. Suppose we could take measurements of the OEM bushings meanwhile rather than waiting.
Old Feb 7, 2005 | 12:16 PM
1FSTMAX's Avatar
bump... has anyone looked into this?
Old Feb 7, 2005 | 03:15 PM
95maxrider's Avatar
Lightly modded
Doesn't ES make them for 5th gens? I can't imagine it being too different from the 4th gen...
What about retrofitting the B13/B14 ES shifter bushing into the 4th gen since we share the same tranny? I think I'm gonna give it a try in the next week or so if I can get the part in time...
Old Feb 7, 2005 | 05:06 PM
1FSTMAX's Avatar
im going to try to install the 5th gen bushings into my 4th gen. I don't think to many maxima owners have installed these bushings.
Old Jan 14, 2006 | 01:41 PM
BEJAY1's Avatar
Conecarver
Just got this from Alfonso. I'm trying another source...
Originally Posted by 1FSTMAX
The trailing arm bushings on the 4th gen are totally different than the 5th gen. The 5th gen ones are two times as big as the 4th gen ones. So they don't fit.
matts95max
Apr 23, 2025 10:44 AM
Maxima.KsA
May 15, 2020 04:14 PM
AcuraLegend
Oct 17, 2016 08:47 PM
Starrider
Dec 18, 2015 04:43 AM
AcuraLegend
Sep 22, 2015 04:22 PM
