Dynoed the PFI Turbo kit tonight 325.83HP & 308.69 lbs of torque AF 10.5:1
Old Oct 24, 2003 | 08:52 PM
JAY25's Avatar
Final run after my own dyno tunning myself
I am boosting 9.7PSI, turbo is a T4/T04E, vortech FMU 8:1 FMU disk, SAFC, Walbro fuel pump and this is Nigels PFI Turbo kit, Thanks Nigel for this sweet kit
http://bigdogjonx.net/fullpics/dyno/Jay25turbo/run5.jpg
10.5 from 4000-redline, was my fuel ratio. I gave myself some cushion since it spikes up to .7 PSI. Did it only once but I am better safe then sorry. I am also not all that greedee for power. Believe me 308lbs of torque is plenty of torque. Pulled on a 300Z TT with big mufflers on it today still in disebelief I did that. Even the driver pulled his windows down to talk but traffic was heavy. I want to say thanks to Dixit (BigdogJohnx) for the help and for uploading these Jpegs to his site and for hooking up that computer to my car. I could not have dynoed my car with his help since I did not have a Chart had a digital AF thing that reads off the numbers to you. My little brother for making sure the MEVI was working etc..
One more question how do you guys figure out what kit puts out best number PSI for PSI?
base run with broken MEVI
http://bigdogjonx.net/fullpics/dyno/Jay25turbo/run1.jpg
started adjustments
http://bigdogjonx.net/fullpics/dyno/Jay25turbo/run2.jpg
http://bigdogjonx.net/fullpics/dyno/Jay25turbo/run3.jpg
http://bigdogjonx.net/fullpics/dyno/Jay25turbo/run4.jpg
the directory in order is here
Old Oct 24, 2003 | 08:55 PM
Jeff92se's Avatar
I'm needing a caw
Holy moly! Nice
Old Oct 24, 2003 | 09:00 PM
KLoWnPR109's Avatar
That's nuts. Give me about 100 hp of that
Those are great numbers
Old Oct 24, 2003 | 09:06 PM
JAY25's Avatar
Dixit insisted on me lowering it down 12:??. This is not like the supercharger that I can predict where I am at all times. This thing can spools up so fast at times in the streets in very very few secs, and leaves me puzzled as to wether I should stay a bit rich to be safe vice sorry for been lean. So this is not the best numbers I can put out. I can put higher numbers if I bring the AF to at least 12:1
Old Oct 24, 2003 | 09:07 PM
AsthmaMax11's Avatar
Awesome numbers Jaime!! how much more HP and TQ is that than your previous setup again?
Old Oct 24, 2003 | 09:10 PM
JAY25's Avatar
last set up was 321.9 HP and 260 ft lbs of torque
4 more HP and 39lbs of torque. And remember my AF ratio is still rich 10.5 to 1 vice last time was 12:1 on the SCer set up.
Old Oct 24, 2003 | 09:17 PM
BigDogJonx's Avatar
Yeap, I still believe if we got the a/f ratio near 12.5:1 or where it put out the best HP, I think we couldve broke 340-350whp. I watched the a/f ratio on all the runs so we could calculate where to make the changes. Reason is that the guy doesnt have the a/f hooked to the dyno computer. But not really an issue if one person watches it.
Man the 1st run he was like 9.5-9.9:1 a/f from 3500-redline.
The computer Jaime was talking about was the OBDII I had hooked up to his car to watch some things and clear codes when the car gave them. We kept getting P0105 which is the absolute pressure sensor, and that was because it ended up stalling on the dyno when the operator hits the brake on it. No biggie, clear it, move on.
Jaime one question I forgot to ask you, when we were driving back to my place, and we ran each other on the hwy, were you pushing it ?
Dixit
Old Oct 24, 2003 | 09:21 PM
JAY25's Avatar
I pushed it only two times the other time I just left it in 5th gear. But dont compare it, do it after we do your project
Old Oct 24, 2003 | 09:38 PM
thebigsadler's Avatar
Not bad.. shouldn't the BB, full T4 put out better numbers though? Would you mind dyno'ing at 5psi
Need to bump the A/F up like dixit said though..
Old Oct 24, 2003 | 09:39 PM
metallic97gxe's Avatar
Master Will
nice more hp more boost
Old Oct 24, 2003 | 09:46 PM
Bags's Avatar
VG Ridah's Biatch Hoe
get 12 A/F and then you'll be rolling and you know it.
awesome numbers
Max4Speed's Avatar
www.autotalk.com
Nice Jaime! I need to dyno tune too. I guess I will need dixit's help too :-D
Old Oct 24, 2003 | 09:53 PM
BigDogJonx's Avatar
Osamah, We will go back up there when the 5spd goes in my car. Should be 2weeks tops.
Dixit
Old Oct 24, 2003 | 10:01 PM
Max4Speed's Avatar
www.autotalk.com
Dixit
Thats kool. Hopefuly I will have all the stuff by then too. Thanks bud!
Old Oct 24, 2003 | 10:14 PM
ivelweyz
I FOUND OSAMAH BIN LADEN!!! Where's my money?!?!?! j/k. Weird thing is, the day after 9/11 happened I met a dude named Osamah...
Old Oct 24, 2003 | 10:15 PM
Max4Speed's Avatar
www.autotalk.com
No wonder you dont have the money yet.. they giving it away for OSAMA not Ossamah ;-)
Old Oct 24, 2003 | 10:18 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Nice!
10chars..
Old Oct 24, 2003 | 10:27 PM
ivelweyz
Our govt probably can't spell...
Old Oct 24, 2003 | 11:27 PM
meccanoble's Avatar
Sports Button FTW
more hp more problems. Jealousy and envy just comes with the territory...a lot of negative energy like my man Jay said.
T-U-R....B-O, a dam TURBO/
every car...next to him looks real slow/
good **** jay, beautiful...just...beautiful
Old Oct 25, 2003 | 12:27 AM
1SICKLEX's Avatar
Jamie, incredible numbers dude!! I love it!
Old Oct 25, 2003 | 02:01 AM
2KxSEx's Avatar
Why not lower the PSI a little bit, but lean out the A/F mixture? This way youll have a cleaner running car that will use less fuel? Im assuming youre running colder plugs... Just my thoughts based on what little information I know about F/I. Very nice numbers by the way, car must pull like a train
Later
Old Oct 25, 2003 | 03:59 AM
JAY25's Avatar
Later
I was previously supercharged pushing 10PSI. I already had 1 step colder plugs in the engine. Now I am pushing .3 PSI less. I know for sure from racing Ramius83, the car will put out close to 350's right where I want to be w/a 3inch exhaust. Jason whats the deal with the Greddys. If we want we will need to buy a complete STI or Subura greddy exhaust system just for the muffler. That is what Greddy told Eric yesterday.
Good idea to lower the PSI, I did had it at 9.5 but instead bumped it to 9.7. I did not know .2 PSI would make a difference and the car pulls even harder. .2 PSI makes a difference I guess
Oh I forgot to tell you guys cost me $50 an hour to dyno tune at this place. $50 it was. $45 to do 3 pulls anytime. Just drop by my house and we will run up there
Oss you can go with Dixit or we can run up there. Baggs dont forget I got your 8:1 disk.
Old Oct 25, 2003 | 05:28 AM
Max4Speed's Avatar
www.autotalk.com
It will all depend when I get all the stuff in. Dont want to tune before everything is done.
Old Oct 25, 2003 | 08:25 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
Good numbers brother...real good. With the proper tuning, you'll be at/past the 350 WHP mark I think (with same or better TQ)...
Old Oct 25, 2003 | 08:32 AM
Redmax's Avatar
Redlinemax Owner
NICE NUMBERS!!!!! hey JAY, what size injectors are in that thing?
Also can you either send me the file or can you post your a/f charts for each run
Old Oct 25, 2003 | 09:15 AM
dmontzsta
dang, now I want boost.
Keep up the good work, you are gaining on Hal.
Old Oct 25, 2003 | 09:37 AM
BigDogJonx's Avatar
Corey, he still running on stock injectors.
We dont have the a/f ratio on a chart because the guy hasnt bought the cable to integrate it with his dyno software. He basically puts in a wideband $450 O2 sensor and its hooked up to this large LED screen. While Jaime made the runs I watched the O2 screen to see where it was an how it moved up the RPM range. Then with what I saw we adjusted fuel trim on his safc. Its not bad because the a/f wasnt hopping around like people think it does. Like from 4000-redlin it moved gradually from 9.9:1 to 10.5:1. So very easy to tune even without the a/f on the dyno chart.
Dixit
Old Oct 25, 2003 | 09:49 AM
|Bijan|'s Avatar
UCF Lexus
Better than I expected! Jaime
Old Oct 25, 2003 | 10:56 AM
Craig Mack's Avatar
All YOUR grammer belong to me
Ya, only 150whp to go.
Old Oct 25, 2003 | 11:26 AM
JAY25's Avatar
if you knew anything about the AF ratio youd see that I did not tune 12:1 . I am satisfied with my numbers thats all that matters to me. Hal is spraying, I am not. My NOS kit is still in the box
Old Oct 25, 2003 | 12:04 PM
Capital15's Avatar
HOly crap!....good numbers.
Old Oct 25, 2003 | 12:39 PM
Craig Mack's Avatar
I didn't say your #'s werent good my friend or that you have the same A/F ratio as him.
Old Oct 25, 2003 | 12:42 PM
Jeff92se's Avatar
I'm needing a caw
Yeah but how many motors has Hal gone though. Better rich than sorry Jay! Better to blow some black smoke than some headgaskets/piston rings!
Old Oct 25, 2003 | 12:44 PM
Craig Mack's Avatar
tu shay Zeffwee, tu shay
Old Oct 25, 2003 | 12:52 PM
|Bijan|'s Avatar
UCF Lexus
He's been there done that x 4
Old Oct 25, 2003 | 01:12 PM
Jeff92se's Avatar
I'm needing a caw
One more idiot remark from either of you gets a temp ban from me. Stop f'ing around in a legit thread.
Old Oct 25, 2003 | 01:24 PM
Cumalot's Avatar
Jaime, when will you take the car to the track? I'm eager to see what will you run. Low 13s? I know you ran a 13.6 with your 10psi SC setup.
Old Oct 25, 2003 | 01:52 PM
MaximaPower's Avatar
nice work Jaime!!
like mike said, can't wait to see track #s
Old Oct 25, 2003 | 02:06 PM
|Bijan|'s Avatar
UCF Lexus
Jaime, you DO know when we were on I-20 last week you were smokin pretty bad right? It was dark blue.....
Old Oct 25, 2003 | 02:38 PM
MaximaRider's Avatar
SiCK #'s Jaime! Guess what, i rerouted the power steering lines today, moved the fuse box back, and removed the horn :-) Im getting there.
