NEED HELP, My Maxima is Dying
Old Oct 28, 2003 | 07:38 PM
jrtexas's Avatar
My apologies of this has been covered, I looked and didn't see anything relevant.
I have a friend who has a 2000 Maxima SE, 5-speed and she has asked me to help her with a problem. The car dies when you coast up to a red light and let off the gas. It always starts right up again without hesitation. Of course, it doesn't do this when the AC is on because the rpms are sufficiently higher. When sitting in garage at idle, it will idle but then it will eventually slow down and die unless you keep bumping the throttle.
I can hear a slight hissing that would suggest a vacuum leak but I simply cannot find it. Using a plastic tube against my ear I confined the hissing to be just below the black fiberglass intake manifold on the drivers side, in the general vicinity of the 1/2" diameter hose that comes up from what appears to be the PCV check valve and onto the gold piping running across the top of the intake. But I simply cannot locate a leak if there is one. There are no MILs, the plugs are new, the gas is good and the car runs great. Any help would be appreciated.
Old Oct 28, 2003 | 07:42 PM
Uconn411's Avatar
Could be a bad MAF, search around or post in the 5th gen. section to find out more.
Old Oct 29, 2003 | 09:38 AM
Street Reeper's Avatar
Handsome
I think you have found the problem already. A bad MAF sensor would cause the car to die when you pushed on the gas. Take the hose that you suspect off and then put it back on making sure to secure it tightly with a hose clamp (does the original still have this?)
There should be three vaccum lines running to the resonator, have you checked all three of these?
Old Oct 29, 2003 | 09:46 AM
tomj's Avatar
Try cleaning her throttle body. Worked for me.
No bad jokes please!
Old Oct 30, 2003 | 01:49 AM
SkylineGTR's Avatar
Have the idle bumped up a little bit. If it isn't a vaccuum leak, it could be a problematic sensor, TPS, CTS or MAF.
TK
Goffery2uned
Aug 21, 2015 09:50 PM
Maxboy23
Aug 11, 2015 11:59 AM
julian888
Aug 6, 2015 04:39 AM
