5th gen trans in a 4th gen???
Old Oct 30, 2003 | 01:23 PM
luckee2bhere's Avatar
I just found a '00 5spd trans with 33k miles for $550 shipped....
Itll work right?
Hasnt someone already done it?
I think it might have been Bejay???
Old Oct 30, 2003 | 01:25 PM
search isnt working for me BTW!!!
Old Oct 30, 2003 | 01:28 PM
Ramius83
Yes, it will work......but ask around about the axles.....
Old Oct 30, 2003 | 01:32 PM
what do you mean about the axles?
Old Oct 30, 2003 | 01:50 PM
D-sta's Avatar
Jeff (Maximus 75) mechanic and owner of www.maximumtuning.net from what I heard people say, has a 6-speed in his superchareged 4th gen.
Old Oct 30, 2003 | 01:54 PM
Ramius83
The tranny will fit in with no problems, but I do not know if the axles are different or not. You need to talk with Dixit (BigDogJonxx or something like that) about this.
Old Oct 30, 2003 | 02:14 PM
6spd??? how the f#$k would that work?
thats an entirely different engine....
Old Oct 30, 2003 | 02:16 PM
Quicksilver's Avatar
OT n00bs FTMFCSL
Maybe it's the same bolt pattern and just needs different housing or something...
Old Oct 30, 2003 | 02:18 PM
JeffesonM's Avatar
living out of a maxima...
I think he said it wasn't really worth the effort because the gear ratios are better on the 5spd.
Old Oct 30, 2003 | 02:24 PM
D-sta's Avatar
I don't know, I never saw it, I just heard he had it, but according to JeffersonM I guess its true.
Old Oct 30, 2003 | 04:14 PM
slizan99's Avatar
it'll def. work. whats the model number off the tranny? that'll help with knowing which axles to get. don't let this tranny get away!!!
Old Oct 30, 2003 | 05:49 PM
BigDogJonx's Avatar
It will work fine, 95-01 are the same tranny, nothing different except supposedly the 4th gen internals are not as strong as the 5th gen ones according to DaveB.
Axels are also the same. No issue. If its that cheap, jump on it.
Dixit
Old Oct 30, 2003 | 06:23 PM
MaxKlinger's Avatar
The more important question is:
Will a SIX speed transmission fit in a 4th gen?
You'd think so, if they fit the 2000-2001 5 speed in the same spot that they fit the 2002-2003 Six speed...and I think the 4 Speed Automagic has been the same from 1995-2003. I'm actually looking around to see if there are diagrams or technical drawings to answer a few questions:
Are all the transmission mounts the same on the 4 speed auto, 5 speed manual, and 6 speed manual transmissions?
Do they all bolt up to the engine the same way?
Are the mounting locations on the frame of the car the same?
Old Oct 30, 2003 | 06:30 PM
BigDogJonx's Avatar
MaxKlinger, when you get a chance, if it is working, do a search and you will see the only person that has attempted this is maximus75 who said he had to do MAJOR work. First off the 6spd is cable driven instead of rod driven. He also said he had to modify the start to make it fit as well.
The transmissions mounts are different, but the engine mounts from a 5spd CAN be used on an auto. Im using actually 2k2 6spd (modified) engine mounts.
Dixit
Old Oct 30, 2003 | 06:53 PM
http://forums.maxima.org/showthread.php?t=260112
Old Oct 30, 2003 | 07:44 PM
BigDogJonx's Avatar
Your linking to the same thread we're in now?
Old Oct 30, 2003 | 07:46 PM
oopS!!! let me fix that!
Old Oct 30, 2003 | 07:57 PM
geo1317's Avatar
he does have it i have seen it in person, but its not a direct bolt on, it takes some work
Old Oct 31, 2003 | 06:50 AM
you guys say itll definitely work???
why are the part numbers different?
from 4/99-6/02 the part number for the trans is different than pre 4/99 for 5 spd maximas...
Old Oct 31, 2003 | 07:24 AM
BigDogJonx's Avatar
Trans part #s are different, but gauranteed it will work. Im about to put a 95 tranny in my 01. Just waiting for the custom LSD to be finished and then DaveB is sending all new parts for the conversion.
Without a doubt it will work. The part numbers are different because they (daveB) says that the 5th gen 3rd gear is stronger than the 4th gen ones.
Dixit
Old Oct 31, 2003 | 07:33 AM
i like the part "they(daveB)"
ha...hows dave B know this?
Old Oct 31, 2003 | 08:07 AM
let me ask you this??? is it an easy fit??? or does it take some work....my man jay25 is doing the work and i dont need to make his job harder...
will someone tell me who has done this already?
Old Oct 31, 2003 | 08:24 AM
BigDogJonx's Avatar
DaveB knows this because he checked the 3rd gear part #s and his documentation where it shows the gear is stronger than before.
I also just talked to Jaime about 5mins ago, and I told him the job is no harder, its the same tranny from the outside, everything bolts up 100%.
Dixit
Old Oct 31, 2003 | 08:45 AM
howd you talk to him?
so Jaime is cool with it?
i was thinking hes at work and i didnt want to bother him...
Old Oct 31, 2003 | 08:53 AM
BigDogJonx's Avatar
He called me on my Cell. He's fine with the swap.
Dixit
Old Oct 31, 2003 | 09:09 AM
Dave B's Avatar
Not DAVEB the parts guy
Man, I need to change my name because it makes for a ton of confusion on this Org. I'm "Dave B" and "DAVEB" is the parts guru. I'll have to ask Jamie about switching my screen name. DAVEB should keep his screen name.
From what I've read, the 00-01 tranny should work. I'd confirm by calling a reputable Nissan parts department. The bolt-pattern, mounts, and clutches are the same and I'd assume the axles are the same. I'd check the tranny number and axles numbers.
Dave
Old Oct 31, 2003 | 09:12 AM
BigDogJonx's Avatar
Dave there is no need to check, i've already confirmed this with a few people including David Burnette and Jeff from MaximumTuning.
Dixit
Old Oct 31, 2003 | 09:20 AM
Dave
lol...my bad dave...
Old Oct 31, 2003 | 10:16 AM
DONE AND DONE>>>>
'00 Max 5spd with 47k miles on its way to jay25's house....
Old Oct 31, 2003 | 03:37 PM
slizan99's Avatar
Old Oct 31, 2003 | 06:00 PM
JAY25's Avatar
Dave
Ill let you guys know how it goes next week when I install it. If all goes well 1995-2001 needs to be added to the facts up top.
Old Oct 31, 2003 | 06:12 PM
if all doesnt go well...im f@#kin screwed...
Old Oct 31, 2003 | 06:20 PM
JAY25's Avatar
It will go well, I am JayDog!
Old Oct 31, 2003 | 07:06 PM
stephenlc's Avatar
Good luck on the install. I would like to know why the 5th gen tranny is stronger though?
Old Oct 31, 2003 | 09:19 PM
BigDogJonx's Avatar
Nissan supposedly changed because of too many claims on the 4th gen trannys falling apart.
Dixit
Old Nov 1, 2003 | 01:51 PM
96shogunmax's Avatar
Hmm...Now I know what tranny I am going with when mine dies. Good info. Stronger 3rd gear.
Old Nov 2, 2003 | 06:31 AM
stephenlc's Avatar
Sweet that helps alot, I spend the extra money for the 5th gen tranny when I do my swap.
Old Nov 2, 2003 | 11:22 AM
extra money?? ha.
$600 shipped for a tranny is about what you'll spend anywhere....just gotta find the right deal!!!
Old Nov 2, 2003 | 11:55 AM
stephenlc's Avatar
600 is pretty good for a tranny. You can usually get a motor cheaper than a transmission.
Old Nov 2, 2003 | 03:33 PM
|Bijan|'s Avatar
UCF Lexus
I saw your car today at Jays house.
Just get a 4th gen tranny w/ under 70k miles
