Attn: SteveChicagoSC / VaporSMX
Old Feb 20, 2001 | 07:46 PM
Lyt97SC
sup there, if i recall correctly, you 2 had experiences with the "PROgram" Ecu system. how did that work out? anything i should know? also do you have the Website for it? thanks guys.
Old Feb 20, 2001 | 09:50 PM
My 4DSC
Hey...
I'm guessing some SC'ed guys will be reading this...
If you get a chance please give some input to my ? too...
https://maxima.org/forums/showthread...threadid=24781
Thanks!
Old Feb 21, 2001 | 05:36 AM
SteveChicagoSC's Avatar
The program did not work out!!!!!
After several hours tuning on the dyno it would show a horsepower increase of 17hp. The next day I would go to the track and I would never see an increase in MPH or ET.
During my testing I would always try to give the PROGram the benefit of the doubt. I would take 3/4 passes down the track. I would then bypass(disconnect) the Program. I would always go a little faster with the stock ECU.
I went back to the dyno taking out the timing changes and then back to the track same results. I noticed the low end was always better with the stock setup. I probably had about 20 passes for test data with always the same results
When I finally returned it. Tony at the racers group(distributor of the program and a nice guy) looked at my fuel/timing maps and stated thats exactly how he would have programmed it.
Two weeks later I put the fields fuel controller($200) on. Tuned it on the same dyno as above an picked up 10 hp. The next day I went to the track and picked up my best time and mph. Go figure.......
I do not recommend the PROGram.
Vesaijan
Feb 27, 2002 01:03 PM
Empz
Sep 15, 2001 11:09 AM
