Update: Electrical problem
Old Nov 6, 2003 | 07:58 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
My drain is gone, and my alternator issue is fixed.
I still have a short I believe, I keep blowing the damn 140A fuse.... they're expensive too - 13 bux from nissan
anyhoo...
new battery, new starter, new alternator
As soon as I put the battery in, I blow the battery fuse after much sparking from the battery terminal when i put the pos. wire back on.
I still have no power locks, no power windows, no intermittent wipers, no stereo, and no ac function.
help
Old Nov 6, 2003 | 08:46 AM
nupe500's Avatar
Jedi Knight
anyhoo...
help
Could you please explain again what caused the initial problems...or what you did...thx
Old Nov 6, 2003 | 08:47 AM
turbomax97's Avatar
my alternator wasn't charging the battery - the alternator turned out to have a bad ground.... now i'm blowing the 140A battery fuse like mad
Old Nov 6, 2003 | 10:05 AM
turbomax97's Avatar
it would help if someone had a wiring diagram of that 140A fuse also..
Old Nov 7, 2003 | 09:25 AM
Street Reeper's Avatar
Handsome
Free Bump, you know I'll be down in December and we will get all the bugs out.
It sounds like you might have two exposed wires touching somewhere. Did you clean everything up after you disconnected your gauges? That was a wiring nightmare underneath your steering column.
knight_yyz
Nov 6, 2015 02:34 PM
