JWT/ECU & MEVI combo finally earns it's keep......14.19 @ 98.54mph
It's about time I got some good results at the track. I am really amazed how well I ran. I left this morning gunning for 14.4's and came home with a 14.19 and a huge smile on my face. My previous best was a 14.60 @96 and the only thing different this time was a gallon of 104 octane race gas added to about 3 gallons of 93 octane.
The best part is that I also ran a 14.34 on my heavy a$$ 17's and had one run with a 99.06 trap
Mods: Intake, Y-pipe, VI, JWT/ECU(7200), findanza flywheel.
set up: removed passanger seat, spare and jack. 11.5lb 15" millenia wheels @ 25psi.
Weather: Mid 30's, sunny, 5mph wind, 50% humidity.
Track was a ghost yard. Only 33 cars running and no wait what so ever. I ran 30 times and could have ran 30 more.
Slip
60' 2.149
330 5.989
1/8 9.149
mph 77.22
1000 11.890
1/4 14.190
mph 98.54
I know this is much faster than my previous times, but I ran 14.2's and 14.3's all day with consistant 98mph traps so it was no fluke run. I don't know if it was the race gas or the weather. Probably a combination of the two but I have ran in cold weather before without these results. If anybody is skeptical I would be happy to scan the slip(s).
Slip
60' 2.149
330 5.989
1/8 9.149
mph 77.22
1000 11.890
1/4 14.190
mph 98.54
That's awsome. Beating your old 60ft by almost a full tenth and your 1/4 by over 4 tenths! I bet you gave a big yell when you got your slip from the post.Did you run those light a$$ mellinia wheels before and what tires were you scootin' down the track on?
Thanks guys.
I finally figured out a way to consistantly pull sub 2.2 60's. Before today I could not break the 2.2 barrier for the life of me. The low rpm launch is what is working, 1200 to 1300 rpms at the most. I had a slew of 2.20's, a pair of 2.19's a few 2.17's and the best was the 2.14.
Jeff, did not change my knock sensor but I think my JWT ECU likes the race gas. I was probably around 96 or 97 octane. The biggest difference today was my driving, but that was not enough to cut my times by 4 tenths and the only other thing different was the gas.
I bet Dave B will have something to say about the race gas when he sees this thread.
Cullen, I am not going to lie, I did a little dance
I have ran with those millenia wheels a few times and just have some all season Firestone's on there. Now I may invest in some slicks or get Neal to let me use his next time we go to the track.
I am no expert on advanced timing and octane levels. I was under the assumption that the JWT ECU was a farily miled upgrade and did not require anything more than 93 pump gas, but how else did I pull over 2mph gain out of my a$$??? It would be nice to see some other JWT ECU owners try some race gas at the track. Now to find out how to run with 97 octane everyday.
Originally Posted by ivelweyz
LSD doesn't do jack for track racing...
So your traction wouldn't be ANY better than if you have an open diff? I always figured that it would help on launching....not a lot, but a little bit.
Originally Posted by 96shogunmax
Its the Summit switch thats doing it for you.
So glad you finally had a great day.
You were pretty bummed that one weekend (so was I). I think the temp did have a bit to do with it. Mid 70's then compared to 31-36 deg yesterday. That's about +8hp. I'm amazed you could hook up as cold as that.
Looks like the 5mph wind was behind you. The better launches helped .1-.2sec prob. And the gas maybe another .1sec.
Consistant runs all year+lots of practice launches+never giving up = hella great showing!
Blu, your car would rape me from a stand still, but I think I could hang with you from a 40mph roll.
Josh, My goal was just to have a low to mid 14 sec car but now that I am so close to a 13 sec run I can't stop now. I may just take the easy way out and run slicks to get into the 13's because I don't think adding a cat-back or UDP or any other bolt on will get me there. If I am not going to use slicks I need another 10 hp to get close to 13's on street tires. I am thinking about the cattman headers and cat-back, but I still need to see some more dyno's first.
Race gas
Congrats Mike. I've always run my best with a mix of race gas (~96-97 octane). I've run all my 14.4s with race gas. I'm about .2 and 2mph slower without race gas. Once I stopped using race gas, I've been stuck in the 14.6s. I think the combination of the ECU and all the extra air we get really pushes the limit of detonation and the boost in octane seems to help things....at least for you and me.
I'll try your launch out this coming weekend.
Dave
Dave
Originally Posted by Dave B
Race gas
Dave
Dave
Race gas
Dave
Dave
Originally Posted by blubyu2k2
Hmmm something else I can try next trip to the track. Thanks for that info
Dave
That's what I used to think too but after DAVE B, mike and some other people told me that they only help maximas in cornering and stuff. Maximas usually leave 2 tire marks when peeling out with an open and closed diff. so that's why I think it doesn't do much...
I wish I had tried race gas this year in my car. I almost got some once but they had closed the pumps like 20 minutes before. Next year I will probably be running race gas every time I hit the track!
Originally Posted by I30tMikeD
I ended up using the 3200 setting instead of the 3400 to get my best traps. So how sensitive is that fine tune control ****. I had no idea is was there unitl you told me. Have you messed with it enough to know how much of a turn it takes to go down 100 rpm's?
Slip
60' 2.149
330 5.989
1/8 9.149
mph 77.22
1000 11.890
1/4 14.190
mph 98.54
Slip
60' 2.149
330 5.989
1/8 9.149
mph 77.22
1000 11.890
1/4 14.190
mph 98.54
Mike,
So you think the race gas made the difference? Do you know the octane rating, Im guessing 100. I have always been under the impression that race gas at the track was a waste of money in N/A cars. The only cars that really seemed to have benefitted were old big blocks or forced induction vehicles. I would like to see a dyno comparison, would be interesting.
So what is it, does the JWT program advance the timing too much, or does it cause the car to run lean up top with the MEVI?? Either way something's not right if someone can run .2 seconds faster in the 1/4 mile on race gas...
Not necessarily true. As far as the MEVI running the car too lean up top. I guarantee that's not it. Our maf can deal with the airflow of 300hp without a problem.
I do not believe JWTs programming is aggressive enough to advance timing to the point of knock on a car that is running right. JWTs program is designed to work with the 91 octane crap they get out in california.
Try this theory on for size. Mikes knock sensor could have been a bit messed up. Because his knocksensor was hypersensitive it was pulling timing a bit thus losing power. However on a car with a knocksensor that was in normal working order, there would have been no retard in timing, thus mike by putting race gas in the car made it so his messed up knock sensor was acting as a WORKING knock sensor should, and did not pull any timing. Thus he was making the power he should have been making all along.
. Wow you car has great top end
