question on 5spd swap...
ok doing reasearch on 5 spd swap and i want to know if anyone out there also swapped their ecu to a five speed ecu.
what exactly did you have to do. did you have to splice any wires???? or did you just plug the auto harness?
i have a 99 maxima and when i decide to do the swap im gonna have to swap the ecu at the dealership so i can have to key programed.
You might want to take a step back and understand that you have a 99.5 and in 99 alone they made over like 15-20 different ECUs. Better make DAMN sure you gettting the right one, other you can do some damage.
I dont know if your 99.5 has a coded key, but I think they did, if so, this aint going to work cause you have to get the NVIS reprogrammed.
Dixit
Dixit
uhhhhhhhhhhhh uh-no so what is the best way to figure out which ecu i sould get. i got an ecu already how would i go about checking if i have the right one or not. i was not aware that there were that many ecu for a 99.5. when i had the parts guy look up a 99 ecu for my car there were 4 choices at/mt fed and at/mt cal. can you tell me where you heard this from so i can do more reasearch.
i can get the key programmed but i would need to install the 5 spd ecu at the dealership before i go into service to have the key programmed.
thanks
thanks
jdmmax,
Here is the list of ECU's for a 99
___________________________________________
Elec Cont Unit (ECU), (under center of dash), SE, MT, Calif, thru 9/98
Elec Cont Unit (ECU), (under center of dash), SE, MT, Calif, from 10/98
Elec Cont Unit (ECU), (under center of dash), GLE, Calif, w/traction control (TCS), thru 9/98
Elec Cont Unit (ECU), (under center of dash), GXE, AT, Calif, w/traction control (TCS), w/power driver's seat, thru 9/98
Elec Cont Unit (ECU), (under center of dash), SE, AT, Calif, w/traction control (TCS), thru 9/98
Elec Cont Unit (ECU), (under center of dash), GLE, Calif, w/o traction control; thru 9/98
Elec Cont Unit (ECU), (under center of dash), GXE, AT, Calif, w/o traction control; w/power driver's seat; thru 9/98
Elec Cont Unit (ECU), (under center of dash), SE, AT, Calif, w/o traction control; thru 9/98
Elec Cont Unit (ECU), (under center of dash), SE, MT, Fed, thru 9/98
Elec Cont Unit (ECU), (under center of dash), SE, MT, Fed, from 10/98
Elec Cont Unit (ECU), (under center of dash), GLE, Fed, w/traction control (TCS), thru 9/98
Elec Cont Unit (ECU), (under center of dash), GXE, AT, Fed, w/traction control (TCS), w/power driver's seat, thru 9/98
Elec Cont Unit (ECU), (under center of dash), SE, AT, Fed, w/traction control (TCS), thru 9/98
Elec Cont Unit (ECU), (under center of dash), GLE, Fed, w/traction control (TCS), from 10/98
Elec Cont Unit (ECU), (under center of dash), GXE, AT, Fed, w/traction control (TCS), w/power driver's seat, from 10/98
Elec Cont Unit (ECU), (under center of dash), SE, AT, Fed, w/traction control (TCS), from 10/98
Elec Cont Unit (ECU), (under center of dash), GLE, Fed, w/o traction control; thru 9/98
Elec Cont Unit (ECU), (under center of dash), GXE, AT, Fed, w/o traction control; w/power driver's seat; thru 9/98
Elec Cont Unit (ECU), (under center of dash), SE, AT, Fed, w/o traction control; thru 9/98
Elec Cont Unit (ECU), (under center of dash), GLE, Fed, w/o traction control; from 10/98
Elec Cont Unit (ECU), (under center of dash), GXE, AT, Fed, w/o traction control; w/power driver's seat; from 10/98
Elec Cont Unit (ECU), (under center of dash), SE, AT, Fed, w/o traction control; from 10/98
Elec Cont Unit (ECU), (under center of dash), GXE, MT, Calif, thru 9/98
Elec Cont Unit (ECU), (under center of dash), GXE, MT, Calif, from 10/98
Elec Cont Unit (ECU), (under center of dash), GXE, MT, Fed, thru 9/98
Elec Cont Unit (ECU), (under center of dash), GXE, MT, Fed, from 10/98
Elec Cont Unit (ECU), (under center of dash), GXE, AT, Calif, w/traction control (TCS), w/o power driver's seat; thru 9/98
Elec Cont Unit (ECU), (under center of dash), GXE, AT, Calif, w/o traction control; w/o power driver's seat; thru 9/98
Elec Cont Unit (ECU), (under center of dash), GXE, AT, Fed, w/o traction control; w/o power driver's seat; thru 9/98
Elec Cont Unit (ECU), (under center of dash), GXE, AT, Fed, w/o traction control; w/o power driver's seat; from 10/98
Elec Cont Unit (ECU), (under center of dash), GXE, AT, Fed, w/traction control (TCS), w/o power driver's seat; thru 9/98
Elec Cont Unit (ECU), (under center of dash), GXE, AT, Fed, w/traction control (TCS), w/o power driver's seat; from 10/98
Elec Cont Unit (ECU), (under center of dash), GXE, AT, Calif, w/o traction control; w/o power driver's seat; from 10/98
Elec Cont Unit (ECU), (under center of dash), GXE, AT, Calif, w/traction control (TCS), w/o power driver's seat; from 10/98
Elec Cont Unit (ECU), (under center of dash), GLE, Calif, w/traction control (TCS), from 10/98
Elec Cont Unit (ECU), (under center of dash), GXE, AT, Calif, w/traction control (TCS), w/power driver's seat, from 10/98
Elec Cont Unit (ECU), (under center of dash), SE, AT, Calif, w/traction control (TCS), from 10/98
Elec Cont Unit (ECU), (under center of dash), GLE, Calif, w/o traction control; from 10/98
Elec Cont Unit (ECU), (under center of dash), GXE, AT, Calif, w/o traction control; w/power driver's seat; from 10/98
Elec Cont Unit (ECU), (under center of dash), SE, AT, Calif, w/o traction control; from 10/98
Enjoy figuring out which one is which.
Dixit
Dixit
ok so that is what i am looking for. no tracktion control.
i have the vin of the car my 5spd ecu came of will carfax tell me everything i need to know. i know my car was built after 10/98. thats was the section i looked under when i got my ecu from car-parts.com
Frank, if you have any questions, give Jon at Finishline a call he has done MANY and would be more than happy to help.
When he did mine he swapped wiring harnesses and ECU, that was the easiest.
Originally Posted by 1FSTMAX
Those are alot of ECU's for 99-99.5.
10 Psi of boost + 5 foward gears
Serious ownage on the 57fwy~!
on him ! ..
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
