Can you put a 95 Cold Air Intake on a 93 DOHC Engine
Old Nov 30, 2003 | 05:34 PM
1swtMaxima's Avatar
I can not find ne thing for a DOHC 93 max is it possible to put a 95 on a 93 is it possible?
Old Nov 30, 2003 | 05:38 PM
gtr_rider's Avatar
192.168.1.1
www.cattman.com
Old Nov 30, 2003 | 05:56 PM
1swtMaxima's Avatar
im askin is it the same or not
Old Nov 30, 2003 | 06:23 PM
happyricefob's Avatar
V^___^V
are you refering to place racing style or injen style?
Old Nov 30, 2003 | 09:46 PM
dmontzsta's Avatar
Ford Only.
I have wondered the same thing, I own both cars and by looking I really dont think it will be a problem at all. If I had a CAI on my 97 I would try it, but I dont.
Old Dec 1, 2003 | 03:23 AM
nubiannupe's Avatar
OG Maxima.org Member
Fellas... to answer your question, it would be YES! (and I say that because my CAI is froma 97 Max) But there are a couple of things you may wish to consider.
For one, the midpipe is different in that it angles slightly moreso on the engine side. Which makes proper alignment a 'touchy-feely' issue.
Second (and this has to do with the midpipe as well), there are two extra holes on the midpipe that aren't used for whatever reason when it's installed on the VE. I simply put a small screw in one of the holes. But the other one was a bit too big for that kinda 'fix', so I tack-welded some light grade aluminum to cover the hole, sanded everything down, painted over the whole shebang, and it looks good to me.
Installing the rest of the CAI, I ran into some of what I found to be 'typical' install woes. That being, I had to relocate the fuse box on the side wall by the battery toward the front of the car by an inch. Still accessible, just moved.
If you need any help, let me know. Pics are on my website, for reference purposes.
Thank you.... please drive through!
Old Dec 1, 2003 | 06:33 AM
Kevincleff's Avatar
yes you are correct, it will fit. pics are on my homepage www.cardomain.com/id/kevin93se
Old Dec 2, 2003 | 12:15 PM
D-sta's Avatar
N34JZ has a place racing intake
www.cardomain.com/id/xrrcd
Old Dec 2, 2003 | 05:41 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
still waiting little piggie - any word yet ?
Old Dec 2, 2003 | 06:27 PM
MrGone's Avatar
will an Injen CAI fit on a VE? opinions?
I have one, just alittle lazy to see if it will work
Old Dec 3, 2003 | 01:27 AM
nubiannupe's Avatar
I would think an Injen would fit, as well. And I'm assuming you have a 4th gen CAI, Shawn... If so, you might run into the same midpipe issues, but that's about it.
Old Dec 3, 2003 | 02:44 AM
KLoWnPR109's Avatar
It could fit, just depends on whether it will fit right or with ghettofying it
Old Dec 3, 2003 | 03:03 AM
MrGone's Avatar
its for a 2000, infact its on my dads 2000.
nupe, what did you do about the IACV? oh wait, you probably have a breather on the valve cover vent thing....
Old Dec 3, 2003 | 09:12 PM
Delvin's Avatar
I got a warpspeed CAI. They say its VE exclusive and the midpipe has the same configuration as the stock one.
95Maxi
Aug 29, 2015 09:38 PM
bc992164
Aug 26, 2015 12:19 PM
cheftoo
Aug 20, 2015 05:17 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
