switching to synthetic???
Don't use 0W30. Stick with 5W30. Don't use heavier grade of oil on a newer car.
Originally posted by JeffO
1st...is Mobil 1 0w-30 okay?
also,
do i need to use flush to prep the engine.
any recommendations?
also,
Re: The switch should be fine...
Be careful about the blends. Some of them are only 5% synthetic. Make sure it shows a high percentage of synthetic. I'm now using Mobil 1. Since I change my own oil, it's roughly the same as paying someone to change it with dino oil. Anyone know where to get Mobil 1 cheap?
Originally posted by Jeff K
Other then draining out the old and replacing it with
new synthetic everything should be fine.
There are synthetic blends of half & half so I would not worry about the change.
Either go 100% synthetic or 100%->
dead dino juice. Blends are a waste of time IMHO. Remember if you use Mobil 1, it's not designed for extended drain intervals so don't run it any longer than you would a dino oil.
Answers to the questions....
Stick with 5W-30...no need to risk the VQ unless ambient/environmental conditions insist....
As for the engine flush/synthetic/etc. visit this post (which, BTW, is one of Jeff92se's favorite posts)
<A HREF="https://maxima.org/forums/showthread.phtml?threadid=398">https://maxima.org/forums/showthread.phtml?threadid=398</A>
AaronL
Aug 8, 2020 10:31 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
