Gas Milage Question
Old Dec 8, 2003 | 07:13 AM
2kprlmax's Avatar
Gas Milage Question
Hey Guys I got a question about gas milage. I have a Greddy Evo and an Intake and I filled up a full take of Amaco Premium in NJ. I just noticed that my gas is under 1/4 of a tank of gas and I only did 210 miles. Is this normal? What are other peoples gas milage.
Old Dec 8, 2003 | 07:16 AM
mzmtg's Avatar
Minister of Silly Walks
Depends. Have you ever meausred your actual mileage? What has it been?
Old Dec 8, 2003 | 07:35 AM
2kprlmax's Avatar
I remember in the past getting closer to 275 even 300
Old Dec 8, 2003 | 08:29 AM
Wisky97SE's Avatar
I notice you're from NY, if you have been driving through the blizzard this past weekend, letting your car idle for long periods of time, sitting in traffic for long periods of time, you cant expect a 325mile tank.
Also, measure the Miles per Gallon, not the Miles per tank, miles per tank is inconsistant. Fill up your tank at Gas Station A, do not top it off. Reset trip odo. Drive as much as you want, it should be under 1/4 tank when you refill it, it doesnt have to be running on fumes. Refill at Gas Station A (try to get the same pump, it could make a difference if you're on an angle at another pump, etc). Now, do not top off, record the amount of gallons used, and divide the recorded milage of the trip ODO by the # of gallons used - this is your accurate MPG. You could do this 5 times and average it out to determine your average MPG, because your driving habbits differ during different times and conditions.
Old Dec 8, 2003 | 09:48 AM
2kprlmax's Avatar
hmmm ok i have let my car idle alot this past weekend and trying to get thru the snow i have been giving it alot of gas. I guess the winter time isn't a good time to check gas milage.
Old Dec 8, 2003 | 09:55 AM
ivelweyz
How is miles per tank inconsistent? You have the same amount of gas used in both instances. You can't have one without the other. Measuring your gas mileage with half or quarter of a tank left is inconsistent. Measuring MPG or miles per tank is the SAME thing if he's on empty...
Mar 12, 2020 12:06 AM
NERDJUSTBNME
Sep 30, 2015 03:20 PM
sdotcarter
Sep 2, 2015 09:53 PM
