Where in the FU%$ is Joint connector F107 located? in a 4th gen..other stuff too
Dec 13, 2003 | 02:14 PM
The car is running. I had the fuel lines reversed. Shot in some sarting fluid and crunk right up.
Now, I still have the 0102 MAF code. I checked the MAF with another car. My MAF is good.
I am checking the wires and the is a joint connector that the shield of the MAF wires taps into. I am trying ot locate joint F107.
I can SEE it in the FSM. EL-318. I can't tell where it is in relation to the car.
Also, while in cold start mode the car idles decent. Comes out of clod start, after it has warmed up, and the idle goes to hell. I also have a vaccum lek. I am seeing 10 HG in vaccum.
So I am trying ot get the car in a driveable condition. It stalls now when you put it in N.
Also just to confuse the situation more. While in cold start black smoke is coming out of the exhaust. Running rich.
After warm up it goes away and @ 1000-1200 RPM the EGT is close to 400 C. It WAS NEVER that high beofre the motor swap.
It would not get above 300 C.
SO I AM RUNNIGN LEAN. I am trying to figure out if it is the MAF or Vaccum leak or both.
I want to torch it and drink bacardi until I can't see.
I am SOOOO close.
Any thoughts?
Dec 13, 2003 | 04:22 PM
I am SOOOO close.
Any thoughts?
I totally feel you. I have been having the hardest time trying to fix my car (Read my reply #13 to mzmtg's post). It has been misfiring. However being 17, having a limited budget and experience, it is not easy. Hope you figure it out.
Dec 13, 2003 | 09:22 PM
Quote: Where in the FU%$ is Joint connector F107 located?
You're right, that diagram is confusing. However, F107 is near F101, which is the ECM harness. So, I'd assume its in behind the radio.
Congrats.
I would assume the bad idle is because of the vaccum leak...but I'm sure you knew that.
400C=752F. that doesn't sound unreasonable. Hell, at idle I'm around 700F. Maybe you were too rich before?
Dec 14, 2003 | 11:41 AM
Quote: You're right, that diagram is confusing. However, F107 is near F101, which is the ECM harness. So, I'd assume its in behind the radio.
Congrats.
Thanks man.. I could not figure that out
Maybe your right about the richness
and BTW I have another thread for you now
Dec 14, 2003 | 12:39 PM
i think you need to do the "maf ground mod" it "regrounds" the current wire. u splice into hte current ground wire and add a wire that is connected to a good ground i believe. search for more info
