Cattman SS Y-pipe Install
Old Aug 22, 2000 | 02:19 PM
Umer95SE's Avatar
Hi Guys,
How difficult is the Y-pipe install? Are there any key issues with it? I work on my car quite a bit so mechanical inclination is not a problem. I just wanted to know if the bolts unscrew easily or not or are there any special things I should be considering.
Old Aug 22, 2000 | 03:21 PM
Maxhawk's Avatar
Depending on the age of your car, the bolts...
for the downpipes may be rusted. When I did mine I used an impact wrench to loosen and remove the bolts. You may want to apply some WD-40 or other lubricant to help free the bolts.
If I remember correctly, you'll also need a u-joint to get to a couple of them. Otherwise a very straightforward install.
Old Aug 22, 2000 | 05:16 PM
GregP's Avatar
I have some pretty detailed info on the Cattman SS Y-Pipe install on my web site.
http://grprete.jnet.net
2kmaximel
Sep 16, 2015 03:19 PM
Violator
Sep 9, 2015 10:14 AM
Samedi
Sep 3, 2015 01:07 PM
