Update on my suspension problem->
Old Feb 28, 2001 | 09:02 AM
1MAX2NV's Avatar
After looking at the front strut assembly some more, I now understand what the strut bearing does. When you turn the steering wheel to the extreme right or left, the whole strut assembly suppose to pivote/rotate on the bearing. The whole strut assembly includes the upper isolator, the spring and the strut. This is what's happening on my passenger side strut assembly. When I turn the steering wheel, the top/upper isolator is not pivoting. The lower part has to pivot because it's attached to the steering knockle. Since the top is not pivoting, the spring itslef is rotating instead. Everytime the spring moves, it makes a clunking sound. Now, I wonder if it's the bearing that's seizing or is something else is interfering with it ie Stillen Camber plate. The bearing is just a piece of plastic, so I don't know how that could go bad.
Old Feb 28, 2001 | 09:29 AM
seven's Avatar
i remember reading in SCC
that the stillen camber plates will increase the noise level of the suspension, but i don't think the springs are supposed to rotate. don't you have camber bolts? i used camber bolts with the same setup and it worked fine.
anyways good luck.
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
