Is my air/fuel gauge is working right?
Old Jan 7, 2004 | 07:06 PM
maxspeed96CT's Avatar
The original VQ...
I just changed an oxyegen sensor and blablabla.... but anyways my air fual gauge used to bounce around alot. Now it stays at stoich and goes to lean at high rpms, is this what its soposed to do. (sorry can't search)
Old Jan 8, 2004 | 07:01 AM
skandalouz's Avatar
i thought it was supposed to go rich at high rpms??? could be wrong
Old Jan 8, 2004 | 07:49 AM
The original VQ...
wel they says having intake and exhaust can make a car run lean but i am coming to realize this thing is pointless.
Old Jan 8, 2004 | 08:00 AM
ejj's Avatar
ejj
No, you're correct.
Old Jan 8, 2004 | 09:33 AM
InfamousG's Avatar
My air fual gauge allways reads 3 or 4 bars stoich, and at WOT its Rich.
i have mine tapped in at the OXy sensor near the cat on the B-pipe.
You can tweek the ratio by a few bars with a adjustable fuel pressure regulator.
If its real bouncey as you say try re-grounded it better, dont ground with cig ligther or amps etc, do the same with leads.
Hope this helps
Old Jan 8, 2004 | 01:47 PM
The original VQ...
Hope this helps
hummm ... what mods do you have cause i have mines hooked up to the front 02 sensor . mines is about in the middle of stoich and goes to lean at wot, the weird thing is before it used to bonce around like crazy and i changed one of my 02 sensors.
Old Jan 8, 2004 | 02:03 PM
Blu's Avatar
Blu
the tits
it should bounce around on steady throttle. If you go WOT or blip the throttle it should go 2-3 bars in rich (green)
Old Jan 8, 2004 | 05:33 PM
CullenJ76's Avatar
The A/F guage is pretty pointless in functionality. It's a show-thing more or less. It's not very accurate at all, but if you want to get a more accurate reading...
do this: http://www.fastmaxima.com/images/dia...AF%20Gauge.jpg (credit to Hal)
Blubyu is right about it bouncing around on steady throttle
Old Jan 8, 2004 | 06:28 PM
skandalouz's Avatar
what is that a diagram of?
Old Jan 8, 2004 | 06:33 PM
CullenJ76's Avatar
that's the ecu pin diagram from a 4th gen. the highlighted are the pins that you tap into to get a signal feed to the guage
Old Jan 8, 2004 | 07:28 PM
The original VQ...
when you guys say bouncing around do you mean all the wayback and forth cause mines bounces around but stays in the stoich area. Also does the knock sensor have anything to do with it cause mines is broken.
Old Jan 11, 2004 | 09:21 AM
WizzaMax's Avatar
Autometer had a picture of a "properly opertating A/F gauge" and it showed it bouncing all over...
so mine was obviously wired incorrectly...cause it stayed about half stoich then rich at WOT like many others...
Analog A/F meters like this one may be more useful than the light show...
Quite a bit can be learned from th e following link abou tA/F and EGT gauges...
http://www.scuderiaciriani.com/rx7/AF_meter.html
Old Jan 11, 2004 | 04:26 PM
MaxiSpeed97's Avatar
Which A/F wire(s) do you tap into those pins on the ECU?
Mine is not bouncing at all, it's always stoich closer to the rich area. When I just rev it gets richer by about 2 or 3 units and goes back. At WOT it stays stoich for about 2 or 3 seconds then becomes as rich as it can get. Any way I can fix this?
Old Jan 11, 2004 | 08:00 PM
The original VQ...
mines deos the same hing exept my car goes to lean at WOT, are you gettin any codes?
Old Jan 11, 2004 | 08:43 PM
nissanfreak's Avatar
Thats odd because my gauge goes to rich when I go WOT. Isnt that where its supposed to go?
Old Jan 11, 2004 | 09:22 PM
CullenJ76's Avatar
I can't remember right now, but I believe it's the purple wire. Forgive me if I'm wrong, but there is a black and white wire for +/- then a signal feed wire which i believe is purple.
Old Jan 12, 2004 | 07:32 AM
The original VQ...
I have the white wire taped on the front 02 sensor (i think ) i have to make sure.
Old Jan 12, 2004 | 04:03 PM
CullenJ76's Avatar
like i said, i can't exactly recall, and it's a little cold outside to be taking apart my car so.....
I really remembered it being purple because that was such an odd color.
Old Jan 12, 2004 | 04:39 PM
WizzaMax's Avatar
mine was teh white...and i said before I dont think it was working according to Autometer's picture.
Old Jan 12, 2004 | 05:14 PM
CullenJ76's Avatar
maybe it is the white wire?
maybe I'm thinking of one of my other guages.
Old Jan 13, 2004 | 09:12 PM
I'm looking at the installation instructions that i've found, and no i think that the shop didn't instal mine correctly. I have a 5" tach w/shift light and an A/F gauge both hooked up to my cruise control as the 12V Dash Lighting and whenever my shift light goes off my A/F reading goes lean by 3 or 4 units.
Red goes to Igniton, white and black is +/- and the violet wire hooks up between "Powertrain Control Module (PCM)" and the "Connector" with leads to the O2 sensor. When i looked, the only wire which was hooked up to my ECU was the green wire from the tach going to the tach terminal.
MAXSE5SPD
Sep 17, 2022 04:00 AM
Hailstatejig
Sep 2, 2015 06:52 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
acw
Aug 13, 2015 12:50 AM
kenc15
Aug 5, 2015 08:29 AM
