cold = shifting thru molasses
Old Jan 14, 2004 | 08:10 AM
das's Avatar
das
Holy carp....its so cold outside that it seems as if I'm shifting thru molasses w/my 5 speed.
any solutions to this? has anyone used synthetic tranny fluid to compensate?
das
Old Jan 14, 2004 | 10:33 AM
nismos14's Avatar
§è~® f®ÈÄk
let the car warm up for 1 minute shift slowly, come off the clutch a lil slower than usual should help a bit
Old Jan 14, 2004 | 11:16 AM
Grisadiche's Avatar
i get that too, so i just shift slow as hell in the mornings.
Old Jan 14, 2004 | 11:49 AM
ToYLeT902's Avatar
JET Speed Lab
Does your clutch feel mushy too? mine does.
Old Jan 14, 2004 | 12:03 PM
Ant96GLE's Avatar
I wish I had that problem
Old Jan 14, 2004 | 12:20 PM
ToYLeT902's Avatar
JET Speed Lab
Sucka!!!!
Old Jan 14, 2004 | 12:29 PM
endus's Avatar
An atavistic endeavor...
One minute doesn't do it with the temps around here lately. I've been having to warm my car up for 5 minutes or more just o have it be safe to drive. I moved my mom's 2k max this morning and I almost crashed into the curb trying to turn the wheel. The max does okay once you warm it up but DAMN do those fluids thicken up...
Old Jan 14, 2004 | 06:37 PM
mitch33x's Avatar
This is my second winter using Redline MT-90 tranny fluid. It helps tremendously over the OEM fluid.
Old Jan 14, 2004 | 06:45 PM
geo1317's Avatar
ill second that, with the mt-90 i have no problems and im running an ACT clutch and a B&M STS, warm up the car for a minute and off i go even when it 0 in the morning.
Old Jan 14, 2004 | 06:58 PM
I30tMikeD's Avatar
redline MT-90. First winter with it and it makes a big difference!
Old Jan 15, 2004 | 06:49 AM
endus's Avatar
I've been meaning to change my tranny fluid since the first time I came to the org. Next summer, or if it's ever warm enough to be outside for more than 5 minutes again, I am totally changing it.
Old Jan 15, 2004 | 12:32 PM
Black95Se's Avatar
Redline all the way. You have no idea how much it helps in the winter.
Old Jan 15, 2004 | 12:43 PM
ejj's Avatar
ejj
I've used Redline, stock and now I've got Amsoil tranny fluid. The tranny always feels stiff when its really cold out.
I do notice less grinding with the synthetic fluids though.
Old Jan 15, 2004 | 12:48 PM
deezo's Avatar
I let my car warm up for about 20 mnutes in this type of cold. Driving off in under that amount of time makes my car feel like the brakes are engaged. The tranny is frozen and the grease in the wheel bearing get stiff as fark. I just drive slow until things come back to life.
Old Jan 15, 2004 | 01:03 PM
ejj's Avatar
ejj
Warm up as in letting it sit there and idle? I don't think that's the best idea...you want to get the oil pressure up so things start moving. I start driving it right away (within a minute), and just keep the engine under 2k RPM.
Old Jan 15, 2004 | 01:28 PM
deezo's Avatar
I drive off after a minute most times but I do this to also make sure my tranny fluid is warm too. When temps get this low, I believe you have to extend your warmup times especially in autos.
Old Jan 15, 2004 | 02:05 PM
davebond007's Avatar
synthetic gear oil = owns in the cold weather.
I have mt90 in my ve 5spd and love it.
Old Jan 15, 2004 | 02:10 PM
maxmobile's Avatar
its not too bad at 0 with the stock fluids... its at -40 where I have a problem at... but then again it happens to all manual cars... I just shift slow and try not to pass 2000rpm until things warm up... ill try to switch to redline when I get the B&M STS
Old Jan 15, 2004 | 02:18 PM
spirilis's Avatar
yep, MT-90 in my 2000 5-speed and while it feels a little "molasses-like" in <20F temps, it's still manageable and definitely shiftable.
Usually at those temps, my clutch pedal action feels a little "mushy" too... so I'm impressed that the tranny moves as smoothly as it does.
Old Jan 15, 2004 | 06:48 PM
liqidvenom's Avatar
brotherhood of tq
yea its been very cold here in jersey and i give my car a couple of mins before i start shifting. even with that my cluth feel different and it takes forever and a day for me to get some heat in my car
Old Jan 15, 2004 | 07:05 PM
MrGone's Avatar
I have amsoil in mine, its great. I'll be putting it in my Dad's 2000se 5spd aswell. Redline's good too, but I prefer the amsoil.
Old Jan 16, 2004 | 12:03 PM
99Maxima5sp's Avatar
Yeah, i need to get some Redline, because with the combination of my Exedy Stage 1, Pacesetter STS, and a cold day (in florida people...so like 30-40 degrees, lol) its pretty rubbery and blunt. I get some chatter when im going in reverse getting outta the driveway. As soon as the car gets warmed up, the chatter goes away...
Of course right now, i cant enjoy starting the max in the morning. I have the joy of starting the rental lancer up in the morning . Of course i dont bounce it off the limiter when its cold out now , it must properly warm up...
Eric
Old Jan 17, 2004 | 02:16 AM
Dev's Avatar
Dev
im running amsoil synthetic...and its not that much better than the stock fluid
i got to -20 one day here...and the first few minutes of driving were hell...it took like 5 mins for the idle to come down to normal
when its this cold...not really much you can do other than start things off slow
Old Jan 17, 2004 | 06:12 AM
Frank Fontaine's Avatar
Yeah, that definitely is not cost-effective either for the petrol. The whole purpose of warming up the car is to make the cabin comfortable. You can drive the modern cars from a cold start gently, say shifting at 2000-2500, and that will also warm it up as opposed to just idling. That warm up thing came from another era. Just like in the old days a car had a "break-in" period...
tarun900
19
Dec 20, 2021 06:57 PM
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
