60K tune up.....Hot or Cold plugs for NA performance
I found all kinds of threads in the FAQs/How-Tos on how to change the plugs. What I want to know is do I go 1 step Hotter or 1 step colder for better NA performance......
Hotter is a bad idea. You will lose power, as the ecu will retard the ignition.
You might gain a little from going one step colder, as it will run a little cooler, allowing for a little more advance, but the plugs will also tend to foul out in about half the time.
Remember its about heat range. Hotter is not better in terms of making power, when going above the stock parameters.
Originally Posted by spirilis
How about just staying with stock?
It's worked well so far, right?
If I did go 1 step colder would that hinder performance or do nothing at all?
And yes im going to get NGK.....
Originally Posted by ohannon7
Well I would like to get some that will give me a little better performance. My stock y-pipe, exhaust and intake worked fine too but I changed them out ......
Hell, while you're at it, you might as well hack your ECU and advance the ignition timing all the way to its limit, raise the compression ratio to 14:1, port & polish your intake/exhaust ports, etc...
Point is, changing spark plug heat range usually isn't something you do unless you REALLY have a GOOD reason for it
I thought most people on here changed their plugs out (including changing heat ranges) and not just the Nitrous guys. I figured since they need to be changed, now would be a good time to do it.
The only max that Ive run into w/ different heat range plugs was SamMan32 who had 1 step hotter. His car shot off the line ALOT quicker than mine and I think all he had was a y-pipe.
WRONG....you will LOSE power with 1-step colder plugs, there have been dynos here/mags/elsewhere proving it. However, we are talking about 3-6whp gained or lost *MAYBE*, so it's not noticeable except on a dyno.
Running one step hotter plugs won't induce detonation as long as you're running QUALITY(Chevron for sure) 91+ octane fuel UNLESS it's extremely hot outside and the car is under heavy load, ie loaded going uphill with A/C on or lugging the engine in too tall a gear from a stop.
Considering it's winter, as long as your car is in a proper state of tune, you *WILL* gain power although minimal. Running hotter plugs on higher mileage engines with carbon deposits during summer temps will cause mild->medium detonation on SOME cars.
Personally, I'd run Iridiums with STOCK heat range year round vs. regular hotter plugs.
I suggest people who want information about plugs visit NGK's website. The heat range on the plug has nothing to do with the temperature of the combustion inside the cylinder, rather it deals with how much heat the plug can dissipate from the cylinder. Remember plugs serve two functions. 1) Provide the spark for ignition 2) Dissipate heat
Now what some of you may be thinking about is not changing the heat range, but changing the GAP of the plug. By doing that you can alter the charateristics of the spark and that can cause preignition or detonation (which are not the same thing)
Icy Hot is right. Medicsonic's car ran like crap with colder plugs. We were at the track in Maryland and he couldn't break out of 17's. I was running 16's and killing him in the 1/4.
Ohannon just go with copper instead of platinum.
Well, I just switched to NGK cold plugs and lets just say the dyno leaves something to be desired. My dyno is on my homepage. Some people have suggested some possible reasons for the slightly low power. One suspect is the cold plugs.
Originally Posted by Eric425
Colder plugs run bad in NA? But wouldn't coppers be colder plugs?
I don't know if I lost power for sure, but don't you think my dyno should be a little stronger with the mods I have. Let me get this straight colder plugs are called cold because they are meant for cold climate and have a hotter spark. Is that right? Well I got NGK cold plugs from the dealer and it doesn't seem to have made a difference.
CAN-Toronto FS: Emanage Ultimate and plug/play Harness
knight_yyz
Nov 6, 2015 02:34 PM
JoshG
51
Sep 21, 2015 10:41 PM
Keyno McMike
Sep 21, 2015 07:18 AM
pears
Sep 18, 2015 05:25 AM
