spec clutches
Old Jan 30, 2004 | 06:46 PM
mtcookson's Avatar
spec clutches
Any of you guys use a SPEC clutch on your Maxima? What are your thoughts on it if you do? I'm buying one for my 3rd gen turbo maxima and was curious if any of you guys (any generation at all) have ever used one. Thanks in advance!
Old Jan 30, 2004 | 06:56 PM
pezking4's Avatar
SPEC clutches are great, though I didn't know they made one for maximas. The Fbody guys I know just love the stage II SPEC. I think you'll be well pleased with it.
Old Jan 30, 2004 | 07:03 PM
mtcookson's Avatar
they make them for maximas however i bought one for the 84-86 300zx since it was cheaper and holds more torque than the one made for the maxima. i wanted maximum holding power but with the ability to still drive it on the street so i bought the stage 3. 4 or 6 puck sprung hub disc and heavy duty pressure plate that will hold 515 ft lb of torque...
Old Jan 30, 2004 | 07:07 PM
pezking4's Avatar
Do the flywheel bolts line up with the 300zx clutch or are you going to have to do some re-drilling?
Old Jan 30, 2004 | 07:08 PM
mtcookson's Avatar
they are identical to my knowledge
Old Jan 30, 2004 | 08:19 PM
nismology's Avatar
It can hold 515 lb/ft of torque yet it has a sprung hub?? Uhhmmm...
Old Jan 30, 2004 | 10:58 PM
mtcookson's Avatar
yeah, its a race disc with a sprung hub that allows for less harsh engagement.
http://www.nipponpower.com/drivetrain/clutch/spec.html
Old Jan 31, 2004 | 08:56 AM
pezking4's Avatar
Thanks for the link. Now I have another decision for when I put the new tranny in. Exedy or SPEC..hmmm
Old Jan 31, 2004 | 09:02 AM
BigDogJonx's Avatar
I currently have the stageII kevlar clutch and love it. The engagement is smooth like butter. That coupled with the Fidanza makes it really nice.
Dixit
Old Jan 31, 2004 | 10:31 AM
araffio's Avatar
I love my Spec clutch, no complaints at all.
-Tony
Old Jan 31, 2004 | 12:23 PM
mtcookson's Avatar
do they have the normal break in period of 500 miles or so?
Old Feb 1, 2004 | 07:12 AM
87MustangGT's Avatar
I've got a stage II (or maybe III) in my Mustang and I like it a lot...
Old Feb 1, 2004 | 11:27 AM
mtcookson's Avatar
i've heard from some guys that the pedal feel was better than stock and a centerforce clutch kit. what do you guys think of the pedal feel (pressure)?
Old Feb 1, 2004 | 11:34 AM
Craig Mack's Avatar
All YOUR grammer belong to me
i've got the stage I in my cobra and one or more fingers on the pressure plate is either bent or something, or isn't fully disengaging from the throwout bearing becuase I get harsh pedal vibration/chatter at idle and a little while cruising. Its extremely annoying and is going to wear out my T-O bearing faster. I don't know if this is a deal with SPEC, or if my tranny shop F'ed up, but the tranny shop is denying it of course.
Old Feb 1, 2004 | 11:39 AM
BigDogJonx's Avatar
Ive got a stageII and the pedal feel is probably same or lighter than stock for some reason. Which Im not complaining about, I like the lighter pedal feel. I checked Jay25's max who is running the ACT and the pedal is at least 2-3x harder.
Dixit
Old Feb 1, 2004 | 04:20 PM
MrGone's Avatar
Dixit
same with me, but I'm running a stage I Exedy
Old Feb 1, 2004 | 04:47 PM
Shadow's Avatar
If it is a problem with SPEC, their warranties are very good. I'm one of their distributors, and anytime anyone has had a problem with a clutch, they've taken care of it. But the unfortunate part is, you'd have to find out if your tranny shop is to blame or SPEC.
Old Feb 2, 2004 | 09:46 AM
mtcookson's Avatar
got one more question for you guys. how many miles have you put on your clutches so far?
Old Feb 2, 2004 | 12:09 PM
BigDogJonx's Avatar
Ive got over 3000miles on my stageII so far.
Old Feb 2, 2004 | 08:18 PM
Craig Mack's Avatar
Ya, how on earth do I do that?? They have told me its normal with spec clutches (tranny shop) so they would just deny it.
Old Feb 3, 2004 | 08:54 AM
Deckdout2's Avatar
Play with my balls
i have a stage III Spec Clutch, check out my www for a driving impression on a 6-speed legend coupe
Old Feb 5, 2004 | 08:25 PM
mtcookson's Avatar
got my clutch in today but i'm going to wait to install it until i can get a lightweight flywheel which should hopefully be soon.
Old Feb 5, 2004 | 09:24 PM
mtcookson's Avatar
isn't that clutch a stage 4? i'm pretty sure the stage 4 clutches have the solid hub like yours whereas stage 3 only has spring hub like mine. (unless its an older model or something and they changed it all since then)
Old Feb 5, 2004 | 09:39 PM
MrGone's Avatar
I for see an IC in your future.
Old Feb 10, 2004 | 07:10 PM
mtcookson's Avatar
ic? i have one... just have to install it
the 300zx turbo clutch and pressure plate does fit the maxima flywheel so all maxima's 85-99 should be able to use this clutch
Old Feb 10, 2004 | 09:13 PM
Deckdout2's Avatar
Play with my balls
actually, that's how any stage clutch comes for my car, since the spring is in the flywheel not the hub. legends have a dual mass flywheel, that's why we can't shave it down, but i think a guy is working with spec to get a lightweight flywheel produced for the legend. the reason you see a 6-puck vs 4-puck is that was also an option for the stage 3, the 6-puck is a little more forgiving.
Old Feb 10, 2004 | 09:16 PM
mtcookson's Avatar
ahh, i see. that's cool.
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
Quickywd01
Sep 21, 2016 09:36 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
