Dull clunking noise from front suspension.... what could it be?
Old Feb 25, 2004 | 05:18 PM
NYCe MaXiMa's Avatar
Driving over any little bumps on the road.. at any speed, there is a dull knock/clunk coming from the right side... especially heard/felt when sitting in as a passanger. It is like dribbling a basketball only more dull.. I also feel that my steering response is not as good as it was..
1. What could it be?
2. how do I single out the problem?
So far, I came up with ball joints, tie rod ends, control arm bushings? perhaps upper strut mounts?
but how do I know which one it is?
thanks a lot.
Old Feb 25, 2004 | 05:29 PM
95GreekMaxSE's Avatar
upper strut mounts, replace them on both sides. They hold the struts to the body of the car and bounce around more freely when worn, thus causing your suspension knock.
Old Feb 25, 2004 | 05:44 PM
thanks.. are you sure?
can they be changed without removing the strut and spring assembly?
also.. we are talking about the things you see when opening the hood, holding the top of the strut on each side with 3 bolts, right?
thanks
Old Feb 25, 2004 | 06:05 PM
LithiuMax
Mine clunked like that on both sides for about a day. Turned out that the main strut tower bolts weren't tightened all the way.
Old Feb 25, 2004 | 06:12 PM
yeah, i had that happen before I've checked for that.. definitely not the problem.. but that is the exact clunking noise that i am hearing right now..
Old Feb 25, 2004 | 06:48 PM
drewm's Avatar
I also had that same problem, but only because a locking washer snapped in half, causing the tower bolt to become loose.
I'd take a look at that nut first, at least it's a fix that will cost you $0, and you can do it yourself.
Old Feb 25, 2004 | 06:58 PM
gtr_rider's Avatar
192.168.1.1
It cant be the strut tower mounts because I installed new ones with me lowering, and it makes it still. It must be something thats in the lower portion of the suspension because thats all that was reused in my install.
Old Feb 25, 2004 | 07:47 PM
Max96LSU's Avatar
i hear that clunking in the rear once in a while.. can't seem to figure where it's coming from....
Old Feb 25, 2004 | 08:31 PM
gtr_rider's Avatar
192.168.1.1
Yea, in the right rear also sometimes..
Old Feb 25, 2004 | 11:53 PM
spiff56747's Avatar
i used to have a clunking noise going over bumps, especially when turning right... i replaced like every single part in the suspension but i still had it
it turns out the bottom of the spring was hitting against the metal spring seat on the strut...where it curves upward to hold the spring in place... i just had to bend back the spring seat a little bit
Old Feb 26, 2004 | 05:43 AM
gtr_rider's Avatar
192.168.1.1
hmm, that sounds like a good idea.. Do you have a picture of the bend?
Old Feb 26, 2004 | 10:17 AM
ChillWill2000's Avatar
bc
Old Feb 26, 2004 | 01:46 PM
strut mounts are 50$ a piece here damn..
this better be the problem. lol
Old Feb 26, 2004 | 02:18 PM
Ladzio's Avatar
I've got this problem, too. Clunking in right rear especially when I have people sitting in the back seat, read few threads here that say that could be a strut going bad... what do you guys think it is...
Thanks.
Old Feb 26, 2004 | 04:11 PM
will i be able to see if they are busted once i remove the strut?
Old Feb 26, 2004 | 04:24 PM
maximase86's Avatar
I love lamp.
Well from what I see from your symptoms, your noise is definately probably the strut assembly. The easiest to find out is if you still have the rubber insulator the sits between the top of the spring and the strut mount, and the bottom of the spring and the perch that the spring sit on the strut. If you don't have anything, what you can do is put some 3/4 wire loom around the first 1 or 2 winds on each side. That may solve it. The other thing to check is to make sure you have the top hat/space piece that sit between strut mount and the car itself. It comes up thought the center hole and positions it self around the top portion of the strut mount. Often people leave this out or they converted thier struts from electronic adjust that didn't have it and it causes noise. The last thing that is probably causing it is the main nut that holds the strut to the mount is loose. Those are the normal suspects.
S
Old Feb 26, 2004 | 06:54 PM
gtr_rider's Avatar
192.168.1.1
courtesy has a good deal on those strut mounts, .orgy discount
Old Feb 26, 2004 | 08:30 PM
Open ypur hood and turn your steering wheel left to right while paying attention to both center bolts for the struts. If either one moves around while the steering wheel is being turned than it's the upper strut mount. Good idea to replace in pairs.
Old Feb 26, 2004 | 08:32 PM
Are all of your bolts torqued tight enough? Are your strut bearings new aswell?
adamgalazka
Feb 5, 2023 08:24 AM
dvcamp
Sep 18, 2015 10:17 AM
GregL65
Sep 5, 2015 09:37 PM
jfl330
Sep 4, 2015 01:44 PM
