why get a y-pipe
Old Mar 13, 2001 | 08:26 PM
Llfe's Avatar
why should i get a y-pipe or ne 1 else...my friend told me that it's gonna be useless if i don't get new headers and a new exhaust system...is that right...
diagram with only a y-pipe
header y-pipe exhaust
diagram with y-pipe, header, and exhaust
is it useless for me to get a y-pipe if i'm not going to get a new exhaust system and headers?
Old Mar 13, 2001 | 08:42 PM
Kevin Wong's Avatar
why?....BECAUSE
jk. Well, apparently the stock y-pipe is the most restrictive with its material, volume, crimps, and junk inside the pipe. The stock header seems to be fine, no one has developed an aftermarket header so I'd say it probably is just fine the way it is. From what I've seen, headers is more of a 4 cylinder's gain. Besides do you realize how difficult it would be to change the Maxima's headers. I think everyone's word and dyno print-outs supplies enough evidence that the Y-pipe is a great performance mod. I'm looking to get a Ca/NLEV cattman ss y myself.
Old Mar 13, 2001 | 08:56 PM
SmoothMax's Avatar
OG
The y-pipe is hardly useless. Dyno's have proved that over and over again. Like Kevin said, no one has manufactued an aftermarket header for the Max. And again, like Kevin said, it would be hell tryin to install the thing. Y-pipe is one of the best performance mods you can get for the Maxima, excluding Nitros or a Supercharger. No offense, but your friend doesn't know what he's talkin about.
Old Mar 13, 2001 | 09:41 PM
Llfe's Avatar
i think ur right
i think ur right. my friend has a ford zx2 and says that he can beat me...lol...if the warpspeed y-pipe gets rid of the stock cat, do i really need aftermarket cat or can i just drive without it?
Old Mar 13, 2001 | 10:15 PM
BriGuyMax's Avatar
1. I can tell you from personal experience that a y-pipe with an otherwise stock exhaust system makes a very noticable difference.
2. Your friend drives a FORD ESCORT.....I wouldn't listen to a word he says.....my friend drives a FORD TAURUS SHO (that for some reason he thinks is really fast...even though I kick his *** all the time) and he said the same thing to me before I got my y-pipe.
3. none of the y-pipes get rid of the Cat....they just get rid of the pre-cats. The pre-cats are there becuase the cat doesn't work until it gets VERY hot...and in the meantime the pre-cats clean the air so it gives off less emmisions when it's cold. But, who needs pre-cats!! Unless you are a tree-hugger or something. Once the car is warm the cat functions normally...and you can pass emmision tests no problem. Anyway, the y-pipe is the most impressive modification that I have installed on my Max.
Go with it
-BriGuyMax
Old Mar 13, 2001 | 10:41 PM
Kevin Wong's Avatar
hey BriGuyMax
Do you plan on get a B-pipe when you pu the 2000 Maxima muffler on? I ask because my next project is my exhaust system, which will consist of the Cattman SS y-pipe, 2000 Maxima muffler, Stillen B-pipe, and RT Cat. I'm looking to spend under $800 for all this.
Old Mar 13, 2001 | 11:31 PM
Llfe's Avatar
thanks...so should i get aftermarket cat or not?
Old Mar 14, 2001 | 05:52 AM
theblue's Avatar
to put it simple, your friend is completely wrong...
the y pipe is the best upgrade for a maxima not because of the size of the pipe, but because it takes out the two precats... these precats are not the same as your regular cat, they are extra. The stock regular cat is not too bad and I would not replace it unless you have already replaced your entire exhaust and intake system.
Your stock system
---88--8---
After Y-Pipe
-------8---
Old Mar 14, 2001 | 07:26 AM
breaux124's Avatar
Aftermarket Y-pipes allow for much better airflow, which equals more power and it's lighter than the stock Y-pipe. Stillen claims an extra 20hp from the Y-pipe, but I'm pretty sure it isn't that high, but it's still one of the best bang for the buck power mods.
Old Mar 14, 2001 | 10:29 AM
Synki's Avatar
The Y-pipe is w/o a doubt one of the best bang for the buck on the Maxima. It has been dynoed & provened to make more HP. The stock y-pipe is very restrictive, it holds 2 precats. You can go with either Stillen, Cattman, or even WSP Y-pipe. No matter which brand, you will still make a good amount of HP.
HP figures vary on each car/mods but you will def. notice a big difference. The aftermarket Y-pipe will eliminate 2 precats. You can use a R/T car or a straight pipe or even your stock cat and leave it in.
They don't make headers for our cars either.
BTW, your boy's Ford ZX2 will not beat your max. Tell him to stop inhailing the fumes from his "new escort".
Old Mar 14, 2001 | 11:46 AM
chottomax's Avatar
The y-pipe should also increase the life of your engine significantly...
Old Mar 14, 2001 | 11:52 AM
theblue's Avatar
please explain...
Quickywd01
Sep 21, 2016 09:36 PM
lrb6805
Sep 17, 2015 04:49 PM
Violator
Sep 9, 2015 10:14 AM
