Should put hood pins in?? *pic*
Old Mar 3, 2004 | 10:21 AM
gramenis's Avatar
I just got some hood pins off ebay from Custom Maxima and am debating on whether or not I should install them. The carbon fiber hood is from VIS and latches better than the stock hood.
Here's a picture:
Old Mar 3, 2004 | 10:37 AM
Conrad283's Avatar
I need a truck
I would if I had a CF hood
Old Mar 3, 2004 | 10:42 AM
Ceasars Chariot's Avatar
Old Maxima Legend
everyone says to use them. i know that my hood seemed extremely locked in and sturdy, but I went ahead and had them put in.
any time to share your thoughts on this hood you have and its weight ?
Old Mar 3, 2004 | 02:11 PM
EteRnity059's Avatar
Boosted?....
I have hood pins on my CF Hood. When you are driving high speeds (excess of 60mph) the side of the hood flaps and shake a lot. Take a spin at about 80mph and it looks like the hood is going to fall off. Trust me, it's better to be safe than sorry.
Old Mar 3, 2004 | 02:14 PM
|Bijan|'s Avatar
UCF Lexus
Yea go JDM style!!!
Old Mar 3, 2004 | 02:17 PM
thebigsadler's Avatar
i've had 3 carbon fiber hoods on my car now.. all 3 times the hood was latched firmly with the stock latch and it still flipped up... don't waste the time in waiting for it to come unlatched and flip up, it's not fun trust me.
Old Mar 3, 2004 | 02:32 PM
1MAX2NV's Avatar
Most CF hood I seen, the latch is attached to fiberglass. Material of different type have a hard time staying together. ie. Fiberglass and metal. Overtime, it will split.
Old Mar 4, 2004 | 03:49 AM
gramenis's Avatar
Thanks guys!
1MAX2NV: You made a very good point..I am definetly going to install them this weekend.
Old Mar 4, 2004 | 01:18 PM
chris'smax's Avatar
Man this sucks, i was trying to avoid hood pins at all costs
Old Mar 4, 2004 | 05:41 PM
EZEMaxima's Avatar
How about installing a locking hood pin. THey are more low profile compared to the regular ones. When i do order my C/F hood, I'll be getting these too!!
Here is a picture from the summit catalog.
Eric
Old Mar 8, 2004 | 05:44 PM
chris'smax's Avatar
Eric
Yep that looks alot better. thanks for the info bro
Old Mar 10, 2004 | 11:00 AM
Flava_24/7's Avatar
Boosted Panda
The Mr.Gasket ones are the exact ones I got. There really not that big compared to regular hood pins.
I didnt want to go with the regular Ring type. These seem like the will sit alot more flush and the metal circular base is the same size as other hood pins.
My CF hood should be in tomorrow(hopefully) and I will install it then and can post pics if ya want.
Also, what do you guys use to hold your CF hood open since you cant use the hood struts anymore???
Old Mar 10, 2004 | 01:12 PM
1MAX2NV's Avatar
Which CF hood did you buy?
Old Mar 10, 2004 | 01:35 PM
Flava_24/7's Avatar
Boosted Panda
redlinemax. Actually, it came in about an hour ago. Im going to try in get it on in a couple of hours.
Old Mar 10, 2004 | 01:54 PM
Blu's Avatar
Blu
the tits
post pics please
Old Mar 10, 2004 | 02:00 PM
DaThrillr's Avatar
has anyone ever used or heard of terry spirngs? could they be used as a hood pin alternative?
Old Mar 10, 2004 | 07:12 PM
Flava_24/7's Avatar
Boosted Panda
blubyu2k2,
I will post pics tomorrow. I managed to get the hood on tonight but havent put in my pins. Had some issues with the hood fitting. The hood latch was on backwards. I still got to try and play with it and see if I can even out the gaps.
slammed95,
CF tube huh,....hook me up with one then
Old Mar 10, 2004 | 07:50 PM
WizzaMax's Avatar
I have a set of those locking pins...and tried to get them to fit...although the curve of the hood would not allow it on my tries to fit right and lock...i have a set i can sell you that were not completely installed if you wanna try it and see...
Old Mar 11, 2004 | 08:53 AM
Flava_24/7's Avatar
Boosted Panda
Originally Posted by blubyu2k2
post pics please
Here ya go.......
Hood pins will go on tonight after I play with the hoodand try to line it up better.I have a big gap on the drivers side.
Old Mar 11, 2004 | 09:12 AM
Nealoc187's Avatar
SLOW
DONT GET THE HOOD LOCKS. Get pins. The design of those hood locks is such that you cannot use them on a hood that is at all slanted like ours is. If you really want to try to make the hood locks work I can sell you my set.
Old Mar 11, 2004 | 12:56 PM
1MAX2NV's Avatar
FLAVOR247...are you talking about the CF latch being on backwards? Let us know what modifications you did to the CF hood to line up perfect.
Old Mar 11, 2004 | 03:45 PM
Nealoc187's Avatar
SLOW
Those hood locks wont work, you'll see what we mean when you try to install them. Don't go drilling a hole in your hood before you realize they wont work, I almost did that and just as I was about to start drilling I realized they wouldn't work.
I used composite hockey stick shaft to hold my hood open when I had my CF hood.
Old Mar 11, 2004 | 05:29 PM
Taken2DaMax's Avatar
since we are on the subject of whether or not to put on hood pins: If i were to get these things, what would be the cheapest place to get these hood pins?
Old Mar 11, 2004 | 05:34 PM
1MAX2NV's Avatar
Summit racing. Most of them are less than $15. I would look for ones that are made out of aluminum and not chromed steel. The chrome tends to chip off and they will start to rust.
Old Mar 11, 2004 | 06:22 PM
maxfanfromohio's Avatar
Shiver me timbers.
Are the ones on Custommaxima.com any good?
conansriver
Sep 3, 2015 06:38 AM
t6378tp
Aug 24, 2015 07:03 AM
doobadoo
Aug 15, 2015 06:43 PM
Trin1j23
Aug 12, 2015 08:31 PM
sc10692
Aug 9, 2015 09:37 AM
